Beolab 5 digital in and Essence remote?
This post has 6 Replies | 0 Followers
Flere
Netherlands
Posts 345
Flere Posted: Tue, Dec 27 2016 12:15 AM
Is it possible to use the Essence remote (wheely) to control Beolab 5 speaker which are connected to a digital source via SPIF ?
So instead of a Beo4 use the Essence remote to switch the BeoLab 5 on/off and control the volume?
- Flere
smile and enjoy the moment
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Tue, Dec 27 2016 2:59 AM
Yes, it is. You just have to set it up to send commands via IR.
BL5 will turn on/off and adjust the volume nicely.
Dante
Sao Paulo - Brazil
Posts 163
TWG
Posts 1,672
TWG replied on Tue, Dec 27 2016 6:36 AM
But be very careful while turning the wheel: The volume control of the Beosound Essence in IR mode is awfully rough! (new and old generation remote)
CB
> You are Here <
Posts 1,762
CB replied on Tue, Dec 27 2016 9:04 AM
TWG:
Rudi (Perdersen) and me can confirm this...Laughing
http://archivedforum2.beoworld.org/forums/p/20629/169161.aspx#169161
Flere
Netherlands
Posts 345
Flere replied on Wed, Dec 28 2016 5:05 PM
That is good news.
Now I have to figure out how best to connect my Mac Mini digital to the BL5.
And I need a sync cable I assume between the BL5.
Maybe somebody has this set up already running?
Mac Mini digitally connected to the BL5.
BL5 controlled via Essence Remote.
- Flere
Millemissen
Flensborg, Denmark
Posts 14,680
You use a converter optical to coax digital converter.
MacOS automatically locks the volume level to the highest setting.
Then control the volume of the BL5's with a Beo4 (or the 'wheely' in ir mode).
Page 1 of 1 (7 items) | RSS
