Link Options
This post has 4 Replies | 0 Followers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Mon, Jan 9 2017 5:47 PM
Hi - I have a BM6500 which I want to keep in a cupboard with an extra speaker kit - my BM6500 is connected to a link system (video in another room ). I want to connect the speakers to the extra speaker kit so that I cna hear video sources and operate the Beomaster from inside the cupboard. I may have messed up Link and Option settings - does anyone know what these should be please?
Andrew
Frinton, UK
Posts 917
Andrew replied on Mon, Jan 9 2017 6:05 PM
I mean to add that it all works fine until I plug in the extra speaker kit which did work in another setup - when that is plugged in a red light flashes but the receiver doesn't react to the commands.
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jan 9 2017 9:04 PM
I would set the BM6500 to option 0 so the remote eye is off and the TV and link room to LINK 2 for the MCL2A and option 2 for the TV. The manuals are on site here for silver users such as yourself
Peter
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Jan 10 2017 8:36 AM
Thanks Peter - I tried that and checked the wiring in the plugs and MCL unit but still no joy - I think there maybe a problem with the MCL unit - will give it a try with a BM5500 and see if that fares any better
beowild
Posts 53
beowild replied on Wed, Jan 11 2017 10:08 AM
Andrew:
Had more or less the same problem with my BM7000 and 2 MCL Units. After changing the MCL-Units i found the error in the BM7000.
Please consider in your test that not all BM5500 have the Link Option.
Good Luck
David
Page 1 of 1 (5 items) | RSS
