Problems with Beovision 7-55
This post has 26 Replies | 0 Followers
Milo16
Posts 11
Milo16 Posted: Tue, Jan 10 2017 5:33 PM
Hello everyone,
I have a problem with Beovision 7-55 Type No. 7724. The TV has stayed off for 2 years. Wen Turn on ask for the pin and I have tried to put the pin but after put the pin and GO button nothing happen display stay  the same , I have contact B&O and took the master-code from them put the master code and GO button. but the same situation as with Pin. (see picture attached)
Thanks in advance
Millemissen
Flensborg, Denmark
Posts 14,680
Hi milo16 and welcome to Beoworld.
Do you use exact the same Beo4 as before?
(If my memory serves me well - it has to be in Mode1)
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 8:08 AM
Hi Millemissen,
Yes you are right, but can you help with this?
Millemissen
Flensborg, Denmark
Posts 14,680
Which MK/version of the 7-55 do you have?
Is your Beo4 the one with the navi-stick?
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 9:17 AM
I am not shure which MK Version is, tv has been for 2 year off. Type No: 7724 with DVD T2C.
Rob - Danish AV
Melbourne
Posts 376
I have a client in a similar situation. Can't get past the pin code and master code same thing.
im about to ship a toggle beo4 to client and see if that's a solution.
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 10:22 AM
If you find a solution please let me know how.
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 10:35 AM
I have the beo4 but nothing happened
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, Jan 11 2017 11:37 AM
MM is right.  If the TV has been set up for Beo5, Beo6 or the Beo4 Navigation the 'GO' command is different to that of a 'normal' Beo4.
So, with a standard Beo4 you can do everything right up to the point you need to confirm a command with the GO button, then nothing happens...  This is the reason that in the set-up menu you can choose 'Navigation Button' or 'No Navigation Button'
I'm not aware of a way round this, but someone may know.  Once you're 'in' and past the PIN Code you can change the setting to 'No Navigation Button' and use your current remote though...  My only suggestion is to borrow a Beo4 Navigation for now.
Lee
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 11:42 AM
But how to go to setup menu?  Becouse I have the beo4 and nothing happens
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Wed, Jan 11 2017 12:53 PM
I managed this when I programmed my BV6 and into had a Navi remote
I'm sure the GO command is play or pause
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 1:33 PM
and how you resolve that?
Millemissen
Flensborg, Denmark
Posts 14,680
Milo16:
You did not answer my question about the remote version, that you use (and that was used previously) ;-(
Millemissen
Flensborg, Denmark
Posts 14,680
9 LEE:
Lee
Just noticed your post - hmmm!
You are right!
And further....
....if the tv is set to 'with navy' and you use a 'non navi' Beo4or a 'with navi' in Mode 2, you won't get further.
Use a 'with navy' version and change it to Mode 1!!!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, Jan 11 2017 7:26 PM
Milo16:
I am not shure which MK Version is.... Type No: 7724 with DVD T2C.
You have a Mk2.  This is one of the finest televisions B&O have ever made in my opinion!
For the record, whenever you look at anything BeoSystem 3 based (or a BeoSystem 3 itself), if it has a number 7 in the Type Number, it's 3D.
Lee
stefan
200 miles from Struer
Posts 2,920
stefan replied on Wed, Jan 11 2017 8:26 PM
9 LEE:
Lee
Sorry, I didn`t read the whole thread, but if you need the "old" GO button, and you have the Beo4 navi, then just use the PLAY button instead of the SELECT button.
Stefan
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Jan 11 2017 9:00 PM
If this works someone should send you a bottle of red wine Big Smile
Ralf
Milo16
Posts 11
Sorry, remote beo4
Milo16
Posts 11
Milo16 replied on Wed, Jan 11 2017 10:19 PM
I have confirmed to first coment that is beo4
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Wed, Jan 11 2017 10:21 PM
Try putting in the PIN number and pressing stop
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
And that is the one, that originally/2 years ago was used with the tv?
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Jan 11 2017 10:23 PM
I can smell the bouquet....
Milo16
Posts 11
Milo16 replied on Thu, Jan 12 2017 9:52 AM
Yes the same
Milo16
Posts 11
Milo16 replied on Thu, Jan 12 2017 9:53 AM
:) you think that I have not try...
stefan
Posts 2,920
stefan replied on Thu, Jan 12 2017 4:14 PM
So maybe /obviously your BV7 is assigned to Beo4 with navigation button (that`s usually the case with a BV7-55).
Press MENU on your (older) Beo4 and search for something like "Remote Conrol" or whatever it is in your language. You can switch between Beo4
- with navigation button
- without navigation button.
Switch to "without..."
Stefan
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Jan 12 2017 7:56 PM
stefan:
Stefan
He can't get past the PIN Code entry Stefan - that's the issue...
He needs a Navigation Beo4 to get the TV to accept the PIN/Master Code - then he can change it to 'No Navigation Button'
Until he can get past the PIN entry, he's stuck!
Lee
Millemissen
Flensborg, Denmark
Posts 14,680
When you try to help remotely on the forum, you always need precise informations!
After all, that I understand the tv (somehow) is set to navigation with the Beo4-joystick.
I have no further suggetions, than to get a Beo4/navi - set to mode 1 - and to try this out.
http://bogo.custhelp.com/app/answers/detail/a_id/3757/~/which-mode-must-i-use-on-my-beo4-remote-control-with-navigation-button%3F
Page 1 of 1 (27 items) | RSS
