Hello everyone,
I have a problem with Beovision 7-55 Type No. 7724. The TV has stayed off for 2 years. Wen Turn on ask for the pin and I have tried to put the pin but after put the pin and GO button nothing happen display stay the same , I have contact B&O and took the master-code from them put the master code and GO button. but the same situation as with Pin. (see picture attached)
Thanks in advance
Hi milo16 and welcome to Beoworld.
Do you use exact the same Beo4 as before?
(If my memory serves me well - it has to be in Mode1)
Hi Millemissen,
Yes you are right, but can you help with this?
Which MK/version of the 7-55 do you have?
Is your Beo4 the one with the navi-stick?
I am not shure which MK Version is, tv has been for 2 year off. Type No: 7724 with DVD T2C.
I have a client in a similar situation. Can't get past the pin code and master code same thing.
im about to ship a toggle beo4 to client and see if that's a solution.
If you find a solution please let me know how.
I have the beo4 but nothing happened
MM is right. If the TV has been set up for Beo5, Beo6 or the Beo4 Navigation the 'GO' command is different to that of a 'normal' Beo4.
So, with a standard Beo4 you can do everything right up to the point you need to confirm a command with the GO button, then nothing happens... This is the reason that in the set-up menu you can choose 'Navigation Button' or 'No Navigation Button'
I'm not aware of a way round this, but someone may know. Once you're 'in' and past the PIN Code you can change the setting to 'No Navigation Button' and use your current remote though... My only suggestion is to borrow a Beo4 Navigation for now.
Lee
But how to go to setup menu? Becouse I have the beo4 and nothing happens
Eclipse 65V1-32Beosound M5Essence MK2BLI
and how you resolve that?
Milo16: I am not shure which MK Version is, tv has been for 2 year off. Type No: 7724 with DVD T2C.
You did not answer my question about the remote version, that you use (and that was used previously) ;-(
9 LEE: MM is right. If the TV has been set up for Beo5, Beo6 or the Beo4 Navigation the 'GO' command is different to that of a 'normal' Beo4. So, with a standard Beo4 you can do everything right up to the point you need to confirm a command with the GO button, then nothing happens... This is the reason that in the set-up menu you can choose 'Navigation Button' or 'No Navigation Button' I'm not aware of a way round this, but someone may know. Once you're 'in' and past the PIN Code you can change the setting to 'No Navigation Button' and use your current remote though... My only suggestion is to borrow a Beo4 Navigation for now. Lee
Just noticed your post - hmmm!
You are right!
And further....
....if the tv is set to 'with navy' and you use a 'non navi' Beo4or a 'with navi' in Mode 2, you won't get further.
Use a 'with navy' version and change it to Mode 1!!!
Milo16: I am not shure which MK Version is.... Type No: 7724 with DVD T2C.
You have a Mk2. This is one of the finest televisions B&O have ever made in my opinion!
For the record, whenever you look at anything BeoSystem 3 based (or a BeoSystem 3 itself), if it has a number 7 in the Type Number, it's 3D.
Sorry, I didn`t read the whole thread, but if you need the "old" GO button, and you have the Beo4 navi, then just use the PLAY button instead of the SELECT button.
Stefan
Sorry, remote beo4
I have confirmed to first coment that is beo4
And that is the one, that originally/2 years ago was used with the tv?
Yes the same
:) you think that I have not try...
So maybe /obviously your BV7 is assigned to Beo4 with navigation button (that`s usually the case with a BV7-55).
Press MENU on your (older) Beo4 and search for something like "Remote Conrol" or whatever it is in your language. You can switch between Beo4
- with navigation button
- without navigation button.
Switch to "without..."
stefan: So maybe /obviously your BV7 is assigned to Beo4 with navigation button (that`s usually the case with a BV7-55). Press MENU on your (older) Beo4 and search for something like "Remote Conrol" or whatever it is in your language. You can switch between Beo4 - with navigation button - without navigation button. Switch to "without..." Stefan
He can't get past the PIN Code entry Stefan - that's the issue...
He needs a Navigation Beo4 to get the TV to accept the PIN/Master Code - then he can change it to 'No Navigation Button'
Until he can get past the PIN entry, he's stuck!
When you try to help remotely on the forum, you always need precise informations!
After all, that I understand the tv (somehow) is set to navigation with the Beo4-joystick.
I have no further suggetions, than to get a Beo4/navi - set to mode 1 - and to try this out.
http://bogo.custhelp.com/app/answers/detail/a_id/3757/~/which-mode-must-i-use-on-my-beo4-remote-control-with-navigation-button%3F
