Beolink Converter NL/ML or new NL products
This post has 44 Replies | 1 Follower
Bundy
Posts 67
Bundy Posted: Fri, Jan 20 2017 10:05 AM
Hi
I have both masterlink and netlink in house, and the question is should i buy a used blink converter NL/ML to connect them or buy new NL products.
My setup is: Livingroom Beovison 11-46 with beolab 4000 connected. Second livingroom beosound 2300 with beoplay S3 connected. Kitchen Beoplay A6, Barthroom Beolab 2000 connected to Beosound 4 in the office via masterlink. I want to have the same possibilities in the bathroom as in the kitchen, and also connection the beosound 2300  to the NL, is that possible withe the converter?
The alternative is to buy new A6 or the new M5 to the bathroom, and later a A9 in the second livingroom.
Brgds Mogens
elephant
AU
Posts 8,219
elephant replied on Fri, Jan 20 2017 11:23 AM
Several of us have bought ml/nl converters.
Personally I regret my purchase:
1/ I found it difficult to setup (thank you everyone who helped me)
2/ my configuration is difficult for me to use and impossible for the family
3/ I have found it less useful than I expected
I now think a second Essence mark II would have been more useful by using aux-in on both Essences to connected older B&O's via aux-in in each room
BeoNut since '75
Ralf
Hamburg Germany
Posts 189
Ralf replied on Fri, Jan 20 2017 12:03 PM
the setup of the BL/NL is simple.
I needed only a few minutes to get it working. Finetuning takes longer and I discovered bugs as well.
The tabs are named (not exactly) 'What to see on NL' and 'What to see on ML' .
Non possible configurations are greyed out.
Since you have an audiomaster on your ML, the Beolink should be configured as Audio Source.
So you can hear TuneIn, Deezer etc. as N.MUSIC and N.RADIO on your Beosound 4 and  Beloab 2000.
On your NL side  you can hear any source from your Besound 4 that was shared  A.MEM, Radio,CD.
That works fine and reliable. I have a similar configuration with M5 and A6 and Beosound 9000.
For the Beosound 2300 you will have to add an extra Beolink converter, because you can't have two audiomasters on your ML.
The Beosound 2300 cannot be in linkmode, Beosound 3000  SW 3.4 can.
Beoplay M5 is very bass heavy and may not sound very well in your bathroom, which is smaller I suppose  and has heavy sound refelections (mirror etc.). But give it a try,  M5 is a smart little box.
Beolink can provide the time  for your ML. This is a goodie.
Ralf
Bundy
Posts 67
Bundy replied on Fri, Jan 20 2017 2:50 PM
Hi Ralf
Will I get airplay in the bathroom, and the livingroom with the beovision 11,  if I connect an airport express to the A.aux on the Beosound 4. Or should it be to the converter? Now the Beolab 2000 can´t activate the A.Aux on the Beosound4.
Mogens
Ralf
Hamburg Germany
Posts 189
Ralf replied on Fri, Jan 20 2017 4:06 PM
Hi Mogens,
it schould work with the A6 and Beovison 11, i will look into the configuration and make a screenshot.
The A.AUX can be mapped to  NL sources.  This works.
A good question is what will the Beolab 2000 do.
What is possible  is to connect the airport ( i have an chromecast audio) to the AUX (RCA inputs) on the Beolink ML/NL.
This then maps to N.RADIO or N.MUSIC. This is a working configuration.
I sold my Beolab 2000 from our kitchen  last week but i can assure you, that this would work..
Did you have  tried PHONO2 or A.TAPE2 to turn A.AUX on? I don't remember whether this works on Beolab 2000. On Beolink active it depends on software. The beolab 2000 has only 1.1 and that was never changed.
I come back soon with some screenshots.
Ralf
Bundy
Posts 67
Bundy replied on Fri, Jan 20 2017 4:19 PM
Thanks for your help. If I set up the converter with a link eye in my small livingroom instead of the Beosound 2300, I would then have a complete NL product there? Right?
egges
germoney
Posts 303
egges replied on Fri, Jan 20 2017 5:43 PM
recently i posted some screenshots concerning the converter in this thread:
http://archivedforum2.beoworld.org/forums/p/22962/190246.aspx#190246
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, Jan 20 2017 6:03 PM
The BLC is not quite a complete NL product.  You cannot stream Spotify to it, for example.
Stan
Bundy
Posts 67
Bundy replied on Fri, Jan 20 2017 7:36 PM
What is the "join"button on a ML produk/remote? Is that something that has to be assigned?
Millemissen
Flensborg, Denmark
Posts 14,680
Stan:
Stan
But you could add an AirPlay capable device (e.g. a Playmaker) to the line-in of it.
Millemissen
Flensborg, Denmark
Posts 14,680
Bundy:
'a ML produk/remote' - I am sure that you mean in the list of the newer Beo4. There is no 'join' on or a ML product.
'Join' means that you - on the NL-device that gets this command -  can listen to a source, that is active somewhere else on the NL-network.
One example - if a tv program is active in the livingroom, you can listen to the sound in the kitchen, when making coffee there ;-))
Do note: not all sources are 'join-able'.
Bundy
Posts 67
Bundy replied on Fri, Jan 20 2017 8:29 PM
Hi Millemissen
So if i hear TuneIn on my A6 in the kitchen I would not be able to join in on that  on the Beolab 2000 in the bathroom with a BLC?
egges
germoney
Posts 303
egges replied on Fri, Jan 20 2017 9:06 PM
in my setting the TV button of the Beolab 2000 = TuneIn from the A6
Millemissen
Flensborg, Denmark
Posts 14,680
@egges
That is a workaround - and a clever one Yes - thumbs up
.....as long as you can remember that a 'TV' button triggers TuneIn!
egges
germoney
Posts 303
egges replied on Fri, Jan 20 2017 9:50 PM
in my understanding, dear MM, this is no workaround but a setting i did with my old Beo4 to be able to join my main music source on the A6 when sitting in my study at the computer. and that's the great thing with the converter. no matter whether there's TuneIn on the M5, my girlfriends cook show via Line In on the Essence or the news with the Avant: the Converter is able to join everything either with the App or the buttons I decide on the Beo4
Millemissen
Flensborg, Denmark
Posts 14,680
@egges
I agree with you.
Never the less - the question was about the 'join' command?
egges
germoney
Posts 303
egges replied on Fri, Jan 20 2017 9:56 PM
to specify: my main joinable music source is TuneIn, mostly i stream via Airplay and there, of course, you can do the workaround with the Airport Express in one of the available Line In's
Millemissen
Flensborg, Denmark
Posts 14,680
@egges
What happens with your BL2000, it you use the remote to send the 'join' command?
egges
germoney
Posts 303
egges replied on Fri, Jan 20 2017 10:06 PM
@MM: there's no "Join"-button on my Beo4, the IR-eye of the amplifier has a Timer- and a Playbutton and when pressing Play it joins e.g. TuneIn from the A6
Millemissen
Flensborg, Denmark
Posts 14,680
@egges
Do mean that pushing the Play-button on the left side of the control-thing on the BL2000 would make it join-in to an ongoing event on the NL-network?
On both of my Beo4/Navi there is a 'Join' entry in the List - the BROne has it too.
Pushing this triggers the active NL. source on the adressed device.
egges
germoney
Posts 303
egges replied on Sat, Jan 21 2017 8:51 AM
@MM: yes, pushing the play-button on the Beolab 2000 joins one active NL-source. that's another reason why i laid TuneIn on the TV-button: i often joined the Line In of the Essence (i.e. TV my girlfriend was watching) instead of the music playing on the A6.
on my Beo4 no "join" appears switching the List button and my Beoremote 1 is exclusively for the Avant. the settings of the remotes is indeed another science!
Millemissen
Flensborg, Denmark
Posts 14,680
@egges
Great to know that the BL2000 behaves this way!
As for the Join/Beo4 issue:
Do you have the Beo4 with navi?
If yes, did you try to add anything pushing 'red dot/list' -> 'Add' -> 'A/V'?
'Join' should be one of the 'hidden' entries there.
egges
germoney
Posts 303
egges replied on Sat, Jan 21 2017 9:16 AM
no, i've an older Beo4 with the GO-button. just checked: no "join" in the hidden entries there
Ralf
Hamburg Germany
Posts 189
Ralf replied on Mon, Jan 23 2017 10:55 AM
I think there is the limitation, that pushing the Play button on the Beolab will only work, if there is no other audiomaster or videomaster else connected, just the BLC configured as videomaster.
I my setup i have an audiomaster Beosound 9000 and the BLC is configured as audiosource or videomaster.
In that case pushing the Play button turns on always the adio from the Beosound, although it played TuenIn before.
And if the Beosound is in standby and  my A6 or M5 is playing TuneIn pushing the Play button does not join TuneIn, it turns on radio from the Beosound.
Audioslave will not solve the problem, the Beolab 2000 will always contact the audiomaster.
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
A workaround...working in some cases, then!
egges
germoney
Posts 303
here again is my setup with the converter and the Beosound 3000. pushing the Play button joins an active NL-source
egges
germoney
Posts 303
and here i did the settings for the TV button either on Beo4 and Beolab 2000. due to ML role CD and Radio button are fixed
StKong
Copenhagen
Posts 320
StKong replied on Tue, Jan 24 2017 6:56 AM
egges:
here again is my setup with the converter and the Beosound 3000. pushing the Play button joins an active NL source
I notice that in your picture it says join primary and secondary.
What, then, s if you have many NL-sources?
egges
germoney
Posts 303
egges replied on Tue, Jan 24 2017 7:37 AM
StKong:
those are the sources shown up in both the BeoMusic and BeoRemote app for the converter.
2 minutes ago i pushed the Play button of the BeoLab 2000 and it joined TuneIn playing on the BeoSound 35
StKong
Copenhagen
Posts 320
StKong replied on Tue, Jan 24 2017 9:27 AM
egges:
Awesome. How do you like the sound of the 2000, by the way?
egges
germoney
Posts 303
egges replied on Tue, Jan 24 2017 9:40 AM
StKong:
i still love it so much. i bought it in 2001 first for the kitchen. since i moved ten years ago it's under the ceiling in a corner of the bath and it's a real beast. absolutely no need to replace it!!!
btw: later on in the morning i pushed its TV button and it dragged another station from A6's TuneIn, A6 remained silent. a long push on the button turned all devices off
StKong
Copenhagen
Posts 320
StKong replied on Wed, Jan 25 2017 9:19 AM
egges:
Cool. Does the setup ever behave unintentionally?
Ralf
Hamburg Germany
Posts 189
Ralf replied on Wed, Jan 25 2017 9:47 AM
egges setup does notwork for me.
The Beolab 2000 may work if connected to the ML/NL in V.Master Role
I have an Beosound 9000 that will not react to any V.Master commands like TV / DTV. May be in A.Option 2 it is possible
I my case i have configured the ML/NL as Audio Source, this will add 2 new sources to ML which i can select with Beolab 2000 and
BS 9000 as well.  Even on my BV8 i can hear Deezer and TuenIn.
But anyhow the nescessary ML/NL setup  depends much  on what is connected to your ML.
In every case it is possible for you to hear and control Deezer or TuneIn in your bathroom.
I have an Beolab 2000 connected with Wireless1 on my terrace, so i can hear my favorite music during cleaning and mowing my garden.
I considered to change the 2000 to a 3500 which i have unused in my cellar.
Ralf
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Jan 25 2017 10:22 AM
Ralf:
Do you have a NL tv? Do you have speakers connected to the BS9000? Which NL device(s) do you have?
it seems to me option Audio Source is questionable.
Ralf
Hamburg Germany
Posts 189
Ralf replied on Tue, Jan 31 2017 2:35 PM
Carolpa:
Ralf:
Here are my answers:
No NL TV yet, but 2 ML Beovisions, one configured with Option 2 one with 5 (other room)
Beolab 8000 connected to BS 9000
I have 2x Beoplay A6, M5 and Beosound 1.
I can listen to CD, AUX and TV on A6 , M5 ansd BS1 on NL
and to Deezer, TuneIn on my BS9000 and Beovisions.
Ralf
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Jan 31 2017 8:53 PM
Hi Ralf,
Ralf:
Do you mean configured as "Source Centre"? (which would be correct for your setup)
Ralf:
I presume from what you have said above, and in your previous post, that the main room BeoVision and the BS9000 are in different rooms - if so they should both be configured as option 2.
Martin.
Ralf
Hamburg Germany
Posts 189
Ralf replied on Wed, Feb 1 2017 11:19 AM
Yes Source Center.
Option 2 is correct.
The second Beovision is connected with Wireless 1 to the BS9000.
This is a Beovision 8 with no built in clock, so i had a clock issue every time i switched it on the Beosound 9000 clock was set to 00:00.
Beo support told me, that this will not work, but now the Beovison 8 is configured with V.OPTION 5 or 6 and the Beolink BL/ML delivers the time for the ML. Never had an clock issue again.
Ralf
Soren
Denmark
Posts 115
Soren replied on Tue, Feb 7 2017 3:24 PM
On the older Beo4 the command CD2 is the same as JOIN on the new ones.
Søren
Millemissen
Flensborg, Denmark
Posts 14,680
Soren:
Søren
Thanks - I did not know that.
StKong
Copenhagen
Posts 320
StKong replied on Wed, Feb 8 2017 8:39 AM
Soren:
Søren
Søren, this is excellent news. Thanks.
Page 1 of 2 (45 items) 1 2 Next > | RSS
