I don't know for sure, but I would assume that they are wired in parallel and can therefore be used together in the manner that you suggest. Try it first with the converter switched off and see if the two sockets provide connectivity between the BC2 and the BL2000. If this works I would assume all is OK.
Yes you can. That is why there is 2 x ML sockets on the converter. One is traditional ML and one is the newer NL. Think of the connection is as a pass through for continuation of distribution on an a ML network.
Ah, you know... A little B&O here, a little there
Hi Ralf,
when my memories are right i would advice you to remove the converter from the Network Link connection
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
i guess the "link room" is the Beolab 2000. with the "Sources visible on ML" you do the button assignment of your remote heading towards the Beolab 2000. works fine with my old Beo4, e.g. the DVD button pulls HDMI 2 from the Avant, TV button drags TuneIn from the A6. i don't know how it interferes if you use one remote for all products; i have the Remote One for the Avant and the Beo4 for the speakers in the study and the Beolab 2000
