Hello,
I have a problem for the first time with BeoSound 5. I’m transferring a CD from iTunes to BM5 as I always do ( I use a MacBook ), it seems everything goes well because I found the files in the BeoMaster 5 when I check it in the computer. The problem arises when I want to play the songs of this singer in the BS5 and I cannot found it. (I look for artist, song, album, ...) and is not there¡¡¡¡¡ I cannot play it because the BS5 doesn’t found it. The CD is produced in 2000 but the one I have is edited in 2008. In iTunes sounds and works perfectly and I have done exactly the same with more than 200 CD.Can anybody help me?Regards
Thanks for the answer but in the maintenance menu there is "CLEAN UP". Is it that what you meant by Rebuid Server?
No.
I think clean just removes tag entries for albums that you have deleted from the BS5.
B
So, what exactly do I have to do when you say "Rebuild Server" in the maintenance BS5? I don't have this option.
X
