Probems with BeoSound 5
This post has 5 Replies | 2 Followers
xasaca
Posts 3
xasaca Posted: Thu, Aug 16 2012 5:54 PM
Hello,
I have a problem for the first time with BeoSound 5. I’m transferring a CD from iTunes to BM5 as I always do ( I use a MacBook ), it seems everything goes well because I found the files in the BeoMaster 5 when I check it in the computer. The problem arises when I want to play  the songs of this singer in the BS5 and I cannot found it. (I look for artist, song, album, ...) and is not there¡¡¡¡¡ I cannot play it because the BS5 doesn’t found it.
The CD is produced in 2000 but the one I have is edited in 2008. In iTunes sounds and works perfectly and I have done exactly the same with more than 200 CD.
Can anybody help me?
Regards
Barry Santini
New York
Posts 543
Go into BS 5 and Rebuild Server in the maintenance area
xasaca
Posts 3
xasaca replied on Thu, Aug 16 2012 7:02 PM
Thanks for the answer but in the maintenance menu there is "CLEAN UP". Is it that what you meant by Rebuid Server?
Barry Santini
New York
Posts 543
No.
I think clean just removes tag entries for albums that you have deleted from the BS5.
B
Barry Santini
New York
Posts 543
No.
B
xasaca
Posts 3
xasaca replied on Sun, Aug 19 2012 9:33 AM
So, what exactly do I have to do when you say "Rebuild Server" in the maintenance BS5? I don't have this option.
X
Page 1 of 1 (6 items) | RSS
