Regards
Kiran
Born in NL; I ride ML
Kiran:Hi Has anybody used any B&O speakers in the garden? I'm getting the house rewired and need advice on how I will distribute music to the garden. Are there any B&O speakers that are for outdoor? Please help. I have Masterlink and Networklink and can possible do anything with my setup. Regards Kiran
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
i have two Beolab 2000 wireless connected. They are outdoor the whole year! They are protected against rain (mounted under an open roof)
On my terrace i have a beolab 3500.
All for 10 or more years now. I have to clean them once a year because little spiders like them as well.
I bought some spare beolabs but yet not needed them.
All connected with ML and Wirelss 1. The compents where mounted in my kitchen and bathroom before.
Another solution could be using a Beolink Passive conncted to ML and use a pair of professionel Elektrovoice outdoor speaker.
Ralf
mjmedlo:I'm installing some sonance outdoor speakers around a pool. The SR1. Has a sub and 8 satellites. I'm using an essence to make them BeoLink compatible as well as their own distinct source for airplay Bluetooth etc. I'm using an older BeoLink passive as an amp. But the new 2 Chanel amp would work well for this too.
Kiran:Hi MJ Yes you are absolutely correct and I was fully recommended this a year ago during initial talks in installing Control4. I suppose this speaker set still stands and will work perfect with the B&O. I will go ahead with Sonance 👍🏻👍🏻 Regards Kiran
https://www.youtube.com/watch?v=GN7PzImR3TE&feature=youtu.be
I'm planning to install the Sonance Sonarray SR1 this summer, but wondering how to connect it. The installer is adamant about using the Sonance amp SR 2-125 to power it.
How would I connect this to a Beosystem 3? For amp inputs, it has L/R RCA, SPDIF Coax, or Toslink. Can I use a PowerLink to RCA and have it as a speaker zone? If I use an Essence, can I use an RJ45 to RCA cable?
Image of the amp:
http://cdn2.bigcommerce.com/server6200/ruxeh5dd/product_images/uploaded_images/sonance-sonamp-dsp-sr-2-125-power-amplifier.png?t=1473120271
beotex:I'm planning to install the Sonance Sonarray SR1 this summer, but wondering how to connect it. The installer is adamant about using the Sonance amp SR 2-125 to power it. How would I connect this to a Beosystem 3? For amp inputs, it has L/R RCA, SPDIF Coax, or Toslink. Can I use a PowerLink to RCA and have it as a speaker zone? If I use an Essence, can I use an RJ45 to RCA cable? Image of the amp: http://cdn2.bigcommerce.com/server6200/ruxeh5dd/product_images/uploaded_images/sonance-sonamp-dsp-sr-2-125-power-amplifier.png?t=1473120271
