Hi I've got a Beocenter 9000 with a pair of RL60. 2's I also have a Cona Sub. Should there be a significant increase in the bass frequency or not. I have it wired up correctly with good quality cable. Thanks. Phil.
I was a bit disappointed. I wonder if there is any way of lowering the frequency by altering the crossover?
bigphil: I was a bit disappointed. I wonder if there is any way of lowering the frequency by altering the crossover?
I don't think it would do much good. The major problem is that the Cona simply won't reach that much lower than the 60.2's already do by themselves. Altering the crossover would probably just mess up the frequency response and wouldn't add anything you couldn't do with the bass setting of your source.
--mika
Ok thanks what about changing the speaker. . I think it is an 8" 20cm unit.
bigphil:Ok thanks what about changing the speaker. . I think it is an 8" 20cm unit.
Yes that's what I'm after.... so you can hook up an active sub to the RCA ports?
Thanks so it can be any active sub as long as it's got a separate volume control.
Thanks Peter.... time to register on the richter scale.
