Transmitter
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Fri, Feb 3 2017 11:22 AM
Hello All
My TV in my lounge is a BV7-55 and the rear speakers are BL6000's both connected to the 7-55 via PL
When I move house I will not want to connect the speakers to the TV via PL or I may have a Avant-55 by then as it seems to be stable (non Android Version)
As my rear speakers are not Wifi and more than likely never be Wifi what do I need to connect them to the TV Is it Beotransmitter?
How much are they? Do they carry stereo sound so I connect the two 6000's together via PL?
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Duels
England
Posts 2,553
Duels replied on Fri, Feb 3 2017 11:28 AM
I believe you need a transmitter 1 to attach to your BV7-55 and a receiver 1 for each of your speakers. You wont need a transmitter if you upgrade to the Avant.
Seanie_230
UK
Posts 2,278
If I upgrade then my Beolab 6000 would need receiver1 right ?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
One receiver for each BL6000!
And don't forget, you'll need 2 x power for each 6000, then.
Duels
England
Posts 2,553
Duels replied on Fri, Feb 3 2017 11:47 AM
Seanie_230:
If I upgrade then my Beolab 6000 would need receiver1 right ? BLGW - Rekindling the love of ML
Yes. One each.
Seanie_230
UK
Posts 2,278
Does the receiver-1 not carry stereo so you can still daily chain the 6000's?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Feb 3 2017 12:27 PM
Millemissen:
These can be useful: https://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-2-x-iec-c7-splitter-extension-cable-black-p9203
EDIT: Cancel that - didn't realise that the Receiver has a separate PSU.  How annoying!
Duels
England
Posts 2,553
Duels replied on Fri, Feb 3 2017 3:09 PM
Seanie_230:
Nope.
Aussie Michael
Melbourne, AU
Posts 3,730
Ok
If you have the Avant it has a built in "transmitter" so to attach your speakers that are non WISA such as 6000s you need one receiver 1 per speaker
That's so the avant can tell it which is going to be the left and which is going to be the right.
That's the solution I used when I had the avant with BL3 as rears. I never had any issues or drop outs.
If you don't have an Avant you will need a Transmitter 1 as it's not built in to the TV like it is with the Avant.
You can then use receiver 1s with your rear speakers that will talk to the Transmitter 1
Page 1 of 1 (9 items) | RSS
