Hello All
My TV in my lounge is a BV7-55 and the rear speakers are BL6000's both connected to the 7-55 via PL
When I move house I will not want to connect the speakers to the TV via PL or I may have a Avant-55 by then as it seems to be stable (non Android Version)
As my rear speakers are not Wifi and more than likely never be Wifi what do I need to connect them to the TV Is it Beotransmitter?
How much are they? Do they carry stereo sound so I connect the two 6000's together via PL?
Sean
Eclipse 65V1-32Beosound M5Essence MK2BLI
I believe you need a transmitter 1 to attach to your BV7-55 and a receiver 1 for each of your speakers. You wont need a transmitter if you upgrade to the Avant.
One receiver for each BL6000!
And don't forget, you'll need 2 x power for each 6000, then.
Seanie_230:If I upgrade then my Beolab 6000 would need receiver1 right ? BLGW - Rekindling the love of ML
Does the receiver-1 not carry stereo so you can still daily chain the 6000's?
Millemissen: One receiver for each BL6000! And don't forget, you'll need 2 x power for each 6000, then. MM
These can be useful: https://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-2-x-iec-c7-splitter-extension-cable-black-p9203
EDIT: Cancel that - didn't realise that the Receiver has a separate PSU. How annoying!
Seanie_230:Does the receiver-1 not carry stereo so you can still daily chain the 6000's? BLGW - Rekindling the love of ML
