Hi this is a strange one. . My Beocenter 9000 works perfectly then for no reason it won't respond to anything, touch panel, remote control. Then I discovered if I lift the rear right hand side very slightly, doesn't even lift off the feet, it works ok. When this happens listening to the tuner the signal disappears and I get white noise, I lft the back again and it tunes back in. I haven't got a clue any ideas out there please??
Cracked solder joints in the power supply and/or regulator areas.And/or a bad fuse.
