Strange Beocenter 9000 problem
This post has 1 Reply | 0 Followers
bigphil
Posts 69
Silver Member
bigphil Posted: Wed, Feb 8 2017 12:14 AM
Hi this is a strange one. . My Beocenter 9000 works perfectly then for no reason it won't respond to anything,  touch panel, remote control. Then I discovered if I lift the rear right hand side very slightly,  doesn't even lift off the feet, it works ok.  When this happens listening to the tuner the signal disappears and I get white noise,  I lft the back again and it tunes back in. I haven't got a clue any ideas out there please??
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Feb 8 2017 6:19 AM
Cracked solder joints in the power supply and/or regulator areas.
And/or a bad fuse.
Page 1 of 1 (2 items) | RSS
