Hello fellow B&O lovers,
I have a strange problem. My beomaster 5500 sometimes starts without my doing. It' looks like there is a tiny DJ inside my equipment ;). It is always random.
Can anyone direct me for a solution?
Hi
Are you sure it is really random? I suggest to write down time and starting source whenever the BM5500 starts because of the tiny DJ at least for some weeks. My suggestions are:
Good luck
David
Thanks for your options.
Low energy light bulbs can trigger remote commands up to a minute after being switched on. I have this trouble with my Beocenter 7002. Have you covered the sensor to eliminate external causes?
John.
