Hi! I searched a lot and still didn't get a clear answer.
Is it posibble to conect a pre-out non B&O amplifier to a beolab 2?
From what I saw only beolab 11 can be hooked to a non B&O amplifier.
And if it is possible please tell me what cable should I use.
Thank you!
Nobody?
THIS cable should be ok.
Be aware, you will need trigger out on your amp to make this work.
I just ordered some of this (for Beolab 8000/4000).No experience yet.
Best regardsRalf
Kallasr, thx...maybe will work, but for Beolab 8000/4000 you need just regular RCA-RCA cable conected to line-in socket of the loudspeakers and to pre-amp outs of the receiver/processor.
Hope it helps.
I cheked my ROTEL and it does have a 12 V trigger out port. Is that ok for the beolab2/beolab 11?
Look at this cable http://www.soundsheavenly.co.uk/bando-ipodlab2.htm
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Thx Michael, I looked at that cable but it is a mini-jack to powerlink....that is not what I was looking for.
Ralf, indeed this is a problem with beolab when they are not "feeded"for a period and turn off then on...and so on...during a movie.
I am waiting your conclusion and I'll buy this cables if they will keep the speakers awake :)
Liviu
HERE we go!
Ralf
liviu_5F00_o:Thx Michael, I looked at that cable but it is a mini-jack to powerlink....that is not what I was looking for.
