Can you plug a NAS or a HDD directly in to a BS Essence?
This post has 11 Replies | 0 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Sat, Feb 11 2017 6:10 AM
Question
Mr 10Percent
So West, Its Now East
Posts 591
I use a power line LAN from a WD4100 NAS to an Essence connected to a power line LAN across the other side of a room. Not 100% on whether the router plays a part - I suspect it does and that it is the "data pump" for the system.
Millemissen
Flensborg, Denmark
Posts 14,680
Aussie Michael:
Question
No!
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Feb 11 2017 9:58 AM
Millemissen:
Aussie Michael:
Question
No!
What if the NAS had a built in DHCP server?
egges
germoney
Posts 303
egges replied on Sat, Feb 11 2017 10:24 AM
i can't see any improvements/advantages in doing so?!?
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Millemissen
Flensborg, Denmark
Posts 14,680
Guy:
Millemissen:
Aussie Michael:
Question
No!
In most cases a DHCP server already is running on the internet router - this could cause conflicts.
I am not sure, if that was part of the question, though.
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Feb 11 2017 10:17 PM
Guy:
You meant DNLA server....I suppose.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Feb 12 2017 8:22 AM
kallasr:
No I actually did mean DHCP!  I was assuming that there was no other internet modem/router, hence you would need a DHCP server to assign an IP address to the Essence, in effect setting up a mini network.  Hence none of the conflicts that MM mentions.
I can imaging this being used in a holiday home, for example, which has no internet connection and hence no other reason to have a network.  You would need some other method of setting up the NAS through a browser, perhaps by just plugging a laptop into this stand-alone network.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Feb 12 2017 9:38 AM
Aussie Michael:
Question
Hi Michael,
Darn good question ! (that needs some explanations on what you exactly want...)
If by "directly" you mean without creating a network, I think the easiest (and only ?) way is to connect the device that will store, play and convert to an analog signal your music files (a smartphone, a tablet, a computer...) to the line-in plug of the Essence.
Aussie Michael
Melbourne, AU
Posts 3,730
CB:
Hi Michael,
Hi
I was trying to connect my library so I can use it with my essence. That's all
I spoke I can connect it to my router but not sure how that works when I do.
Millemissen
Flensborg, Denmark
Posts 14,680
If the NAS/PC is on the same network as the Essence (2nd gen), there is a DNLA server running on the NAS/PC and this has access to/is pointed to your files, you can use the Beomusic app to play back these files on the Essence.
Not a 'direct connection', but a 'networked connection'.
CB
> You are Here <
Posts 1,762
CB replied on Tue, Feb 14 2017 2:29 PM
Aussie Michael:
A good reading then Wink
http://archivedforum2.beoworld.org/forums/p/11344/99151.aspx#99151
Page 1 of 1 (12 items) | RSS
