Question
I use a power line LAN from a WD4100 NAS to an Essence connected to a power line LAN across the other side of a room. Not 100% on whether the router plays a part - I suspect it does and that it is the "data pump" for the system.
Aussie Michael: Question
No!
Millemissen: Aussie Michael: Question No! MM
What if the NAS had a built in DHCP server?
i can't see any improvements/advantages in doing so?!?
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Guy: Millemissen: Aussie Michael: Question No! MM What if the NAS had a built in DHCP server?
In most cases a DHCP server already is running on the internet router - this could cause conflicts.
I am not sure, if that was part of the question, though.
Guy:What if the NAS had a built in DHCP server?
kallasr:You meant DNLA server....I suppose.
No I actually did mean DHCP! I was assuming that there was no other internet modem/router, hence you would need a DHCP server to assign an IP address to the Essence, in effect setting up a mini network. Hence none of the conflicts that MM mentions.
I can imaging this being used in a holiday home, for example, which has no internet connection and hence no other reason to have a network. You would need some other method of setting up the NAS through a browser, perhaps by just plugging a laptop into this stand-alone network.
Aussie Michael:Question
Hi Michael,
Darn good question ! (that needs some explanations on what you exactly want...)
If by "directly" you mean without creating a network, I think the easiest (and only ?) way is to connect the device that will store, play and convert to an analog signal your music files (a smartphone, a tablet, a computer...) to the line-in plug of the Essence.
CB:Hi Michael, Darn good question ! (that needs some explanations on what you exactly want...) If by "directly" you mean without creating a network, I think the easiest (and only ?) way is to connect the device that will store, play and convert to an analog signal your music files (a smartphone, a tablet, a computer...) to the line-in plug of the Essence.
If the NAS/PC is on the same network as the Essence (2nd gen), there is a DNLA server running on the NAS/PC and this has access to/is pointed to your files, you can use the Beomusic app to play back these files on the Essence.
Not a 'direct connection', but a 'networked connection'.
Aussie Michael:I was trying to connect my library so I can use it with my essence. That's all I spoke I can connect it to my router but not sure how that works when I do
A good reading then
http://archivedforum2.beoworld.org/forums/p/11344/99151.aspx#99151
