Nest Cam
This post has 20 Replies | 3 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Fri, Feb 17 2017 7:30 PM
Hello all
My area has been targeted this month and had over 5 breakin's not nice feeing at all
Police have increase patrols etc in the area but the offenders seem to bust a window grab and run which is scary when your in bed.
Being worried I want to buy a wireless cam asap.
Quick question has anyone setup a nest cam with the BLGW ? If yes I will buy one tomorrow and set it up.
Also I think the nest can alert you if something moves.
Can the cam be shown in home control on the V1 screen ?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Or if you can recommend any other off tjr shelf Cam that allows online viewing and alert if it detects movement. Must be wifi
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
The Beonic Man
Bristol
Posts 812
Nest is OK as a cam. Bit old now without any recent updates and the subscription service puts many off from buying, including myself. Works well enough though if you want to pay monthly for it. Other options are using your existing devices that have inbuilt cams (an iPhone and iPad for example) with a free app such as Surveillance by Reservoir Dev. Link here. Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Feb 18 2017 2:48 PM
I have a Hubble - allows you to set for alerts, both movement and noise. Also cheap! We use it for monitoring the dogs!
Peter
Seanie_230
UK
Posts 2,278
Well this is harder than I thought it would be
The nest is brilliant and offers nice design, access via app and web, online storage BUT no local access for streaming to BLGW
The net gear arla Q is the same great reviews but closed to local access
It appears I need the functionality of a survalience camera but with local IP access which most IP cameras have.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sun, Feb 19 2017 3:44 AM
DoorBird is what I'm using.
Seanie_230
UK
Posts 2,278
Looks like Foscam C1 offer local jpeg URLs for BLGW and viewing via home control on NL products
Also they offer remote viewing via app too :)
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
olvisab
Posts 1,391
olvisab replied on Sun, Feb 19 2017 6:24 PM
A single wireless cam ? That's not a serious way to protect your house.
I have invested into mobotix cam inside and outside, a fierce dog, wired and wireless detector with the alarm system, real and dummy outside siren.
When they have the choice they will choose the less protected house.
That's sad what's happened in your area, but this is an issue also for any area in europa.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
olvisab
Posts 1,391
olvisab replied on Sun, Feb 19 2017 6:31 PM
I would also change my avator for a moment 😬 That's scary !!
Seanie_230
UK
Posts 2,278
I have my alarm and it's visible but I think the cam is for security and more my piece of mind.
Picture will help I will put it on the window Big SmileBig Smile
I have noticed the New BLGW Firmware allows H264 on the new Beolink App but not on home control on NL Tv's that still needs JPEG
Just ordered a Foscam C2 from Amazon for tomorrow delivery Big Smile
Tomorrow I will aim to get it recording and altering and visible in the BLGW
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Today my Foscam C2 1080p camera arrived
It has live view and alters if it detects movement.
More importantly I put the URL found in some CCTV software and immediately on my Beolink App and via homecontrol on my V1 I have my camera view.
Now this works I will buy a few more.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Mon, Feb 20 2017 8:02 PM
Have you found a way to record this feed?
Seanie_230
UK
Posts 2,278
You can use ispyconnet or Foscam offer a cloud based service.
I think I am swaying towards cloud based as then I have to leave my PC running and sync a folder to google drive which I don't want to do.
Seems I have found a solution Big SmileBig Smile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Thu, Feb 23 2017 10:48 AM
This is amazing.
So I have configured a Foscam C2 to my BLGW
I have enabled Khimo on the BLGW and now via my Beolink2 App I can see my camera when sitting at my fathers offices keeping an eye on my home.
Peace of mind
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
boskonay
Posts 76
Has anyone got a Mobotix Door cam working with the BLGW?
BeoMegaMan
Posts 601
boskonay:
Yes. it was being used at last years Cedia display tied into the BLGW.
Ah, you know... A little B&O here, a little there
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Thu, Mar 22 2018 7:48 PM
hi seanie!
can you please help me with the foscam c2? which parameters did you fill in the blgw?
base url with port or without? (port 88 or 554?)
base rtsp url: the same url?
username&passwort or with with the rtsp url?
rtsp stream: /videomain
image?
mjpeg?
thanks a lot!
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Fri, Mar 23 2018 10:04 PM
Hi!
After some trial and error - here are my configuration of the foscam c2 in the blgw:
Maybe not all correct but its working fine. (in the webpanel and beolink and beolink2 app). Any improvements?
base url: "IP-Adresse":88
base rtsp url: "IP-Adresse":88/videoMain
Username: "user"
password: "pwd"
rtsp stream: rtsp://„user“:“pwd“@„IP-Adresse":88/videoMain
highResolution image: http://„IP-Adresse":88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
lowResolution image: http://„IP-Adresse":88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
HighResolution mjpeg: http://„IP-Adresse“:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
LowResolution mjpeg: http://„IP-Adresse“:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
mczac
Posts 49
mczac replied on Fri, Mar 23 2018 11:28 PM
You can pull the images from Nest Cameras and store them locally, but not the live feed.
That requires you to create Nest developer account to obtain credentials for external script running say on your home server. But ideally you want to have 30 days recording and that is only available with pricey subscription, particularly if you have several cameras. On a positive side Cloud processing allows smart objects/face recognition if you aren't bothered with your live feed stored on Google servers.
Nest can also be integrated with HomeKit using homebridge, so you can use detected motion events to trigger lights in your house if no one is home...
BeoHut
Posts 482
BeoHut replied on Mon, Sep 3 2018 9:36 AM
Hi beoandy,
Just bought a Foscam C2 camera. Now I want to use this with my BLGW and want the view of the camera in my Webpanel and on my Avant/V1.
Which driver do I have to use to put in the above parameters?
Can yo help help me or someone else? Thanks in advance!
Greetings from BeoHut
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Tue, Sep 4 2018 7:25 PM
hi beohut!
you need no driver! go in the blgw setup to interfaces and then on the left side to camera.
fill in the parameter as seen on my post above. (let the parameter pan commands, tilt commands and zoom commands free) "ip-adresse" is your fix ip address of your webcam. (without "")
it is working in the beolink 1 an 2 app and in the webpanel. i have no networklink based tv to test it!
beoandy
Page 1 of 1 (21 items) | RSS
DigiCert Secured Site Seal
