Eclipse 65V1-32Beosound M5Essence MK2BLI
Nest is OK as a cam. Bit old now without any recent updates and the subscription service puts many off from buying, including myself. Works well enough though if you want to pay monthly for it. Other options are using your existing devices that have inbuilt cams (an iPhone and iPad for example) with a free app such as Surveillance by Reservoir Dev. Link here. Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
I have a Hubble - allows you to set for alerts, both movement and noise. Also cheap! We use it for monitoring the dogs!
Peter
A single wireless cam ? That's not a serious way to protect your house.
I have invested into mobotix cam inside and outside, a fierce dog, wired and wireless detector with the alarm system, real and dummy outside siren.
When they have the choice they will choose the less protected house.
That's sad what's happened in your area, but this is an issue also for any area in europa.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
I would also change my avator for a moment 😬 That's scary !!
This is amazing.
So I have configured a Foscam C2 to my BLGW
I have enabled Khimo on the BLGW and now via my Beolink2 App I can see my camera when sitting at my fathers offices keeping an eye on my home.
Peace of mind
Has anyone got a Mobotix Door cam working with the BLGW?
boskonay:Has anyone got a Mobotix Door cam working with the BLGW?
Ah, you know... A little B&O here, a little there
hi seanie!
can you please help me with the foscam c2? which parameters did you fill in the blgw?
base url with port or without? (port 88 or 554?)
base rtsp url: the same url?
username&passwort or with with the rtsp url?
rtsp stream: /videomain
image?
mjpeg?
thanks a lot!
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Hi!
After some trial and error - here are my configuration of the foscam c2 in the blgw:
Maybe not all correct but its working fine. (in the webpanel and beolink and beolink2 app). Any improvements?
base url: "IP-Adresse":88
base rtsp url: "IP-Adresse":88/videoMain
Username: "user"
password: "pwd"
rtsp stream: rtsp://„user“:“pwd“@„IP-Adresse":88/videoMain
highResolution image: http://„IP-Adresse":88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
lowResolution image: http://„IP-Adresse":88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
HighResolution mjpeg: http://„IP-Adresse“:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
LowResolution mjpeg: http://„IP-Adresse“:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=„user“&pwd=„pwd“
You can pull the images from Nest Cameras and store them locally, but not the live feed.
That requires you to create Nest developer account to obtain credentials for external script running say on your home server. But ideally you want to have 30 days recording and that is only available with pricey subscription, particularly if you have several cameras. On a positive side Cloud processing allows smart objects/face recognition if you aren't bothered with your live feed stored on Google servers.
Nest can also be integrated with HomeKit using homebridge, so you can use detected motion events to trigger lights in your house if no one is home...
Hi beoandy,
Just bought a Foscam C2 camera. Now I want to use this with my BLGW and want the view of the camera in my Webpanel and on my Avant/V1.
Which driver do I have to use to put in the above parameters?
Can yo help help me or someone else? Thanks in advance!
Greetings from BeoHut
hi beohut!
you need no driver! go in the blgw setup to interfaces and then on the left side to camera.
fill in the parameter as seen on my post above. (let the parameter pan commands, tilt commands and zoom commands free) "ip-adresse" is your fix ip address of your webcam. (without "")
it is working in the beolink 1 an 2 app and in the webpanel. i have no networklink based tv to test it!
