Beomaster 4500. No sound out of power link sockets
This post has 2 Replies | 2 Followers
Melech
Posts 4
Melech Posted: Sun, Feb 19 2017 11:37 PM
connecting to vandersteens. Was clients fathers. Bought 8 pin connectors. Soldered as per diagram that I have. Pin 1 left hot. Pin 3 left ground. Pin 4 right hot, pin 5 right ground. Ground on negative side of speaker. Hot on positive. Nothing. Help!!!!
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Mon, Feb 20 2017 1:04 AM
Are you trying to connect the power link outputs to normal passive speakers? Those outputs are line level not speaker level.
The 4500 has normal 2 pin Din speaker outputs too to drive passive speakers.
MADSYSTEMES ZANUSO
Paris
Posts 29
hi
when you press mute buton do you listen the relay that do klic klic? if not maybe you have something inside the socket head phone or maybe this socket are defect. if you don t use it you can remove the connector inside the main board and the sound will be ok
Page 1 of 1 (3 items) | RSS
