connecting to vandersteens. Was clients fathers. Bought 8 pin connectors. Soldered as per diagram that I have. Pin 1 left hot. Pin 3 left ground. Pin 4 right hot, pin 5 right ground. Ground on negative side of speaker. Hot on positive. Nothing. Help!!!!
hi
when you press mute buton do you listen the relay that do klic klic? if not maybe you have something inside the socket head phone or maybe this socket are defect. if you don t use it you can remove the connector inside the main board and the sound will be ok
