Do a speaker reset. That is, unplug the speaker from the mains. Leave it unplugged for a few minutes, then replug the speaker into the mains.
Around the time that my speakers began to behave badly, this kind of thing happened as well. One of the remedies was to "reset" the speaker. Now, mind you, this symptom may also be attributed to the nasty sounds from the BL20 armageddon thread.
You mentioned your speakers made that sound once, have you had them looked at, boards replaced? If not, this might be an indicator that you should.
