BS9000 - How to install SW Upgrade Chip ?
This post has 10 Replies | 0 Followers
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce Posted: Sat, Mar 3 2012 11:14 AM
Hi all,
yesterday I received the SW 3.42a Upgrade IC I ordered from my dealer for my BS9000 MK3.
After reading the service manual I am a little bit confused. It looks like BS9000 has to be disassembled completly to install the little chip.
Is this true or is there a more easy way to install the upgrade chip.
Any help or a short description what to do excactly would be well appreciated.
Regards
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
replied on Sat, Mar 3 2012 11:45 AM
Martin if you look in the Media section (from the main menu) you will find some pictures of the BS9000 published by Keith that indicate that you indeed need to open up the whole unit to replace the s/w chip.
Regards Rolf
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
What advantages or extra features does this SW 3.42a provide??
Regards Graham
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
joeyboygolf:
If you were upgrading from the previous version 3.3 then it would only be an advantage if you were using a Masterlink Gateway using options 5 or 6
From versions 3.0 to 3.4 provided the following problem solutions:-
  1. Version 3.3 prepared for introduction of new tuner PCB1 for type 257x
  2. Version 3.2 provided a correction to the PIN code system. Locks after five faulty PIN code have been entered.
  3. Version 3.1 provided a solution to the auto-positioning error where CDs were rotating more and more every time lid had been opened. Also half a second of every new CD was missing.
  4. Version 3.0  Was a standard manufacturing released software version.
Regards Keith....
joeyboygolf
Posts 4,188
Thanks Keith
Regards Graham
joeyboygolf
Posts 4,188
BeoIce:
You only need to carry out dismantling steps 1-5 to gain access to the little tin box. Just follow the instructions in the service manual.
The job should take no more than 1 hour even allowing for your "virgin" status.
Remember to take the appropriate anti-static precautions!!
Regards Graham
BeoIce
Posts 751
BeoIce replied on Sun, Mar 4 2012 10:58 AM
joeyboygolf:
Thanks for all your answers.
My "virgin" status results from loosing my post count from the old forum. I already asked Keith to set the counter back to the value I had before.
I ordered an appropriate anti-static mat with wrist band to do the job the right way.
Regards
joeyboygolf
Posts 4,188
BeoIce:
joeyboygolf:
Regards
That was a comment on your experience with fitting the chip, not your experience on BeoWorld!
Regards Graham
BeoIce
Posts 751
BeoIce replied on Sun, Mar 4 2012 11:11 AM
Ok, understand Big Smile
Keith Saunders
Posts 5,495
BeoIce:
You now have your count
Regards Keith....
BeoIce
Posts 751
BeoIce replied on Mon, Mar 5 2012 7:06 AM
Thanks alot Keith Smile
Regards
Page 1 of 1 (11 items) | RSS
