Hi all,
yesterday I received the SW 3.42a Upgrade IC I ordered from my dealer for my BS9000 MK3.
After reading the service manual I am a little bit confused. It looks like BS9000 has to be disassembled completly to install the little chip.
Is this true or is there a more easy way to install the upgrade chip.
Any help or a short description what to do excactly would be well appreciated.
Regards
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Martin if you look in the Media section (from the main menu) you will find some pictures of the BS9000 published by Keith that indicate that you indeed need to open up the whole unit to replace the s/w chip.
Regards Rolf
What advantages or extra features does this SW 3.42a provide??
Regards Graham
joeyboygolf: What advantages or extra features does this SW 3.42a provide??
If you were upgrading from the previous version 3.3 then it would only be an advantage if you were using a Masterlink Gateway using options 5 or 6
From versions 3.0 to 3.4 provided the following problem solutions:-
Regards Keith....
Thanks Keith
BeoIce: Is this true or is there a more easy way to install the upgrade chip. Any help or a short description what to do excactly would be well appreciated.
The job should take no more than 1 hour even allowing for your "virgin" status.
Remember to take the appropriate anti-static precautions!!
joeyboygolf: The job should take no more than 1 hour even allowing for your "virgin" status. Remember to take the appropriate anti-static precautions!!
Thanks for all your answers.
My "virgin" status results from loosing my post count from the old forum. I already asked Keith to set the counter back to the value I had before.
I ordered an appropriate anti-static mat with wrist band to do the job the right way.
BeoIce: joeyboygolf: The job should take no more than 1 hour even allowing for your "virgin" status. Remember to take the appropriate anti-static precautions!! Thanks for all your answers. My "virgin" status results from loosing my post count from the old forum. I already asked Keith to set the counter back to the value I had before. I ordered an appropriate anti-static mat with wrist band to do the job the right way. Regards Martin
That was a comment on your experience with fitting the chip, not your experience on BeoWorld!
Ok, understand
BeoIce: My "virgin" status results from loosing my post count from the old forum. I already asked Keith to set the counter back to the value I had before.
You now have your count
Thanks alot Keith
