COMPETITION TIME !!!
This post has 35 Replies | 3 Followers
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE Posted: Sat, Aug 25 2012 5:00 PM | Locked
We haven't had anything like this for a while, so it's with great pleasure I can launch a .... COMPETITION !!
Big SmileLets have a Party !!!Big Smile
STBbrackets have announced that they have joined forces with Lutron Lighting Solutions throughout Europe. This new distribution agreement is based around the Lutron Rania for Bang & Olufsen dimming solution which is designed for use with BeoLink 1000, Beo4, Beo5 and Beo6. If you wanted to know what the LIGHT button is for, now you know!
Rania replaces a standard light switch and gives remote control light dimming using your B&O remote as well as manual control from the switch.
To win one of three Lutron Rania for Bang & Olufsen you simply need to tell us what killer product you’d like to see from STB. Simple as that..
The best three suggestions win one Lutron Rania each. The competition closes one week from today - so that's midnight on 1st September.  After that, I'll announce the winners within 72 hours, scouts honour.
Good Luck and get your thinking caps on.. Idea
Chris Townsend
Qatar
Posts 3,531
Chris Townsend replied on Sat, Aug 25 2012 7:36 PM | Locked
How about a rubber type bra that fits snugly and discreetly round the Beo 5/6 to stop it falling off the sofa or make it easier in the hand. See through, very thin and almost sticky. Would prevent it from getting damaged too!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Aug 25 2012 8:24 PM | Locked
Okay, I'll kick off with a real suggestion.
An adaptor so you can mount the V1 - 32" on a BeoVision 7 - 32" Motor Floor Stand, or a V1 - 40" on a BeoVision 7 - 40" Motor Floor Stand...
A lot of people would upgrade from their Mk1 and Mk2 BeoVision 7's to a V1 if this was the case I'm sure!  You could even sell your BeoLab 7 to part-fund the purchase of the V1 !!!
Lee
latarsky
Posts 2
latarsky replied on Sat, Aug 25 2012 9:02 PM | Locked
Bracket to hang Playmaker on the wall. I can't understand why there is no such an option... most wanted thing right now.
Chris Harrison
Peak District
Posts 381
Chris Harrison replied on Sat, Aug 25 2012 9:55 PM | Locked
Multi purpose bracket for beovision so that Playstation, Sky HD box and Apple TV can be fitted at the back of the TV - all at once!
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Chris Townsend
Qatar
Posts 3,531
Chris Townsend replied on Sat, Aug 25 2012 10:27 PM | Locked
How about a desktop stand for the Beoplay A3 so it looks like a Beovision 6?
mbee
Paris, France
Posts 1,842
mbee replied on Sat, Aug 25 2012 10:56 PM | Locked
How about a "sofa stand" for the bs5/bs5Encore so that it is at the correct height when used from a sofa or a chair (the high stand is too high and the table stand is to low... Without a table) ?
... Or even a stand that is directl fixed to a sofa!
2012martin
Posts 202
2012martin replied on Sun, Aug 26 2012 12:30 AM | Locked
Latarsky. The playmaker was wall mounted in the shop when I went in
2012martin
Posts 202
2012martin replied on Sun, Aug 26 2012 2:16 AM | Locked
I've always thought that the bs900 would be good on say a bv7-32 motorised stand. Maybe with an external ir receiver to controll the stand with the remote (as the bs9000 has no socket for a motorised stand) I would certainly be interested.
Im not sure but it might be possible to take the pole from the bs9000 stand and put it onto the base of a bv7-32 the pole looks like the same size. So this would just leave how it could be controlled?
2012martin
Posts 202
2012martin replied on Sun, Aug 26 2012 2:17 AM | Locked
Bs9000 not bs900 sorry
Nick
Nottingham
Posts 785
Nick replied on Sun, Aug 26 2012 9:59 AM | Locked
I think Lee has the best idea, even an adaption for the bv8 and make it possible you can use your beolab 7 aswell because the speaker is a big part of surround sound system.
Lee i think you win!!
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Aug 26 2012 12:22 PM | Locked
The Beo4 remote wall mount is not very well made, is expensive, and looks downright ugly when the remote is not in it. It is also possible to knock the bottom retaining lug off the mount if the Beo4 is dropped into it.
If STB brackets could produce a stainless steel remote holder that was held in place on the wall alongside the Rania switch (or any light switch for that matter), that required no additional wall drilling, and looked attractive when the remote was elsewhere, I would think that a high proportion of B&O owners would buy it and B&O stores would stock it.
Graham
danezro
Posts 106
danezro replied on Sun, Aug 26 2012 6:09 PM | Locked
I don't think this exists anwywhere but I could be wrong, it is not on the STB website.
Beolab 6000 wall bracket please.
Dan
Chris Townsend
Qatar
Posts 3,531
Chris Townsend replied on Sun, Aug 26 2012 6:12 PM | Locked
Dan, it does and it looks very good.
http://www.google.co.uk/imgres?q=beolab+6000+wall+brackets&um=1&hl=en&safe=off&client=safari&sa=N&rls=en&authuser=0&biw=1440&bih=759&tbm=isch&tbnid=3Dy-l46FPAHRLM:&imgrefurl=http://www.beoworld.org/news_view.asp%3Fid%3D40&imgurl=http://www.beoworld.org/assets/thumbnails/Nieuwe%252520afbeelding%2525201.JPG&w=310&h=413&ei=KFk6UKC0FMWt0QWN4YCgBA&zoom=1&iact=hc&vpx=170&vpy=125&dur=443&hovh=258&hovw=193&tx=92&ty=144&sig=115698549309057995289&page=1&tbnh=135&tbnw=77&start=0&ndsp=29&ved=1t:429,r:0,s:0,i:73
danezro
Posts 106
danezro replied on Sun, Aug 26 2012 6:50 PM | Locked
Thanks Corbridge, my other suggestion....
Centre speaker bracket for a single Beolab 4, for BV4’s and BV7's.
Great cost effective alternative to BL7's, same juxtaposition as the BV4 / BL10.
Dan
2012martin
Posts 202
2012martin replied on Sun, Aug 26 2012 8:10 PM | Locked
A way of attatching beolab 3s to the side of a beovision 7 or 10 so that the speakers move with the tv.
Rivenflush
Gothenburg
Posts 333
Rivenflush replied on Sun, Aug 26 2012 8:25 PM | Locked
I would really like to see a wall mount for the Beolab 8000 similar to the one for the Beolab 6000. This would really make them look like they are floating in the air.
Another thing I would like to see is a table stand for the Beolab 4000 where you mount the speakers horizontally, i.e. if you like me use them as centre speakers in a surround setup.
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
2012martin
Posts 202
2012martin replied on Sun, Aug 26 2012 9:31 PM | Locked
A bracket to attatch a 3500 to a bv7-32 or bv7-40 motorised stand
Rikard
Sweden
Posts 218
Rikard replied on Sun, Aug 26 2012 10:00 PM | Locked
A cornerbracket for speakers..
One piece that fits the corner and different pieces to fit different speakers..
I really need to corner mount  some speakers, BL4000 and BL3.
Or a wall/ceiling mout for a tv that can turn/tilt and go up and down... So when you not watch tv it is up in the ceiling so the kids cant run into it.. :)
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Aug 27 2012 7:12 AM | Locked
Rivenflush:
You mean like the ones B&O has been selling for quite a while now? Whistle
IMHO they don't work visually nearly as well as the BL6000 wall brackets. The design of the 8000 simply doesn't want any bulk behind the cone.
--mika
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
joeyboygolf replied on Mon, Aug 27 2012 11:46 AM | Locked
tournedos:
Rivenflush:
Turn the bracket upside down then!
Regards Graham
Yendys
Sydney
Posts 312
Yendys replied on Mon, Aug 27 2012 12:59 PM | Locked
Playmaker bracket on the the same angle as a BeoSound 300x and also for a Beosound 4
Yendys
Sydney
Posts 312
Yendys replied on Mon, Aug 27 2012 1:05 PM | Locked
tournedos:
--mika
to be fare these are not easy to locate on any B&O/STB site I tried before I rearranged a room and thought I was dreaming..... so didn't use them unfortunately
madskp
Denmark
Posts 321
madskp replied on Mon, Aug 27 2012 8:33 PM | Locked
How about a bracket for a Power strip combined with som kind of compartment to hide the cables from the Power Strip. Problem with most power strips is that there is no way to mount them.
I know it has to be adjustable in some way to fit all the different types of power strips (American/British/European/?)
Rivenflush
Gothenburg
Posts 333
Rivenflush replied on Mon, Aug 27 2012 8:53 PM | Locked
tournedos:
Ok, my mistake, never saw those before. Totally agree that they are far from perfect though, I would rather see brackets that are less bulky and in polished aluminium.
Another thing I would like to see is a wall bracket for an iPod / iPad that encloses the dock in polished aluminum to better match the design of B&O than the white example below.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, Aug 29 2012 12:25 AM | Locked
As the most vocal and demanding Bang & Olufsen users on the planet,  is this all we can come up with ?
Come on everyone!
Lee
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Wed, Aug 29 2012 1:08 AM | Locked
A bracket that lets you mount any speaker as a centre to a BV7 stand.....
x:________________________
Søren Mexico
Mexico City
Posts 6,411
Søren Mexico replied on Wed, Aug 29 2012 3:50 AM | Locked
We need a horizontal "BAR" with holes to attach different attachments, like 2 tubes or square tubes to place like a BM 4000 or BM 5000 or which ever device that has to be placed horizontally, Also attachment to place a stack system or the devices that can be hung vertically or at 45 degrees. And since we like our music also a possibility to hang a board below the Items if wanted
The Base Bar has to be available in different length like 600,800, 1000 Mm. and diff. colors like Black, white and aluminum. Maybe smaller ones for book shelf speakers
The Base Bar has to have space for cables, enough space to easily get cables in and out, maybe 75 x 40 Mm. The 75 Mm. also to give some stability when attached to a wall,
For cable runs, horizontally or vertically beside the base bar, there has to be cable channels available in the same colors and diff. length. Also constructed to easy placement of cables. like lid of, place cable, lid on.
The horizontal base bar and the attachments has to be as "invisible" as possible when the items are placed on the attachments.
So my suggestion: Base bar and Attachments for all Beo models
marcus_m
Posts 517
marcus_m replied on Wed, Aug 29 2012 7:41 AM | Locked
We have a BV10-32 where the back of the set is visible while you walk by. All available mounting solutions are intended for scenarios where the TV set is placed right in front of a wall, but are pretty ugly if the back is visible.
So a mounting solution for additional components below the easel stand whould be helpfull. It hast to be just a simple plate cut like the original weight. In the attached picture you see a Beomedia1 (yes, not in the original case, I know!) mounted below the stand so that it is not visible from the front.
Cheers, Marcus
Jonathan
Posts 1,811
Jonathan replied on Thu, Aug 30 2012 8:44 AM | Locked
I'd also like a better looking stand for the new V1
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael replied on Thu, Aug 30 2012 9:37 AM | Locked
jldmelb:
I'd like a stand for the V1 that doesnt raise the height but keeps the screen upright and doesn't tilt,so you can place it on a chest of drawers and watch it in bed.
elephant
AU
Posts 8,219
elephant replied on Thu, Aug 30 2012 9:55 AM | Locked
Michael:
jldmelb:
Maybe even tilt forward ? or do you sit up in bed Smile
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael replied on Thu, Aug 30 2012 10:28 AM | Locked
elephant:
Beo-Ed :-)
1/2 hour of Midsomer murders on my apple tv and I'm a goner ! I half lay half sit. What's that called? A split ? Haha.
My chest of drawers from jimmy possum is 86 cm high so I don't want a high stand ;-)
Rivenflush
Gothenburg
Posts 333
Rivenflush replied on Sat, Sep 1 2012 7:31 PM | Locked
Why not an "adapter" for the V1 to the motorized stands that are used for e.g. Beovision 6 and 7.
Rivenflush
Gothenburg
Posts 333
Duplicate
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Sep 3 2012 2:09 PM | Locked
Okay everyone. I ran this a couple of days longer to see if we had any further posts, but it seems the creativity ran dry.
I've now locked this thread - and will forward the suggestions to Gavin at STB Brackets.
I'll announce the winners later this week. Yes - thumbs up
Lee
Page 1 of 1 (36 items) | RSS
