Hi all
Love this place wish id found it years ago.
I have been given a PS3 for my bday :)
down side is a cant get my be BeoV 3 to recognise it anyone had the same or similar issue?
thanks in advance
Will
Will64: Hi all Love this place wish id found it years ago. I have been given a PS3 for my bday :) down side is a cant get my be BeoV 3 to recognise it anyone had the same or similar issue? thanks in advance Will
Hello there,
Check you have it on the right input and that the 3 phono cables are in the correct holes on the scart adaptor. Then make sure the ps3 is off then hold the on button down, dont let go until it beeps for a second time, then you should get an image.
