connecting a PS3 to a BeoV 3
This post has 1 Reply | 0 Followers
Will64
Posts 3
Will64 Posted: Wed, Aug 29 2012 1:35 PM
Hi all
Love this place wish id found it years ago.
I have been given a PS3 for my bday :)
down side is a cant get my be BeoV 3 to recognise it anyone had the same or similar issue?
thanks in advance
Will
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Thu, Aug 30 2012 2:43 PM
Will64:
Hi all
thanks in advance
Will
Hello there,
Check you have it on the right input and that the 3 phono cables are in the correct holes on the scart adaptor. Then make sure the ps3 is off then hold the on button down, dont let go until it beeps for a second time, then you should get an image.
Page 1 of 1 (2 items) | RSS
