new (to me) bv7-40
This post has 15 Replies | 0 Followers
Nick
Nottingham
Posts 785
Nick Posted: Sat, Sep 1 2012 9:59 PM
Hi all,
  I have bought a bv7-40 i cant get it to keep my pentas switched on, even though i have told it they are there? my overture also connected to it is on??  I assume its an option setting somewhere?
Can anyone help>
Thanks Nick
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Sep 1 2012 11:28 PM
Hi Nick,
if Pentas are connected to BV 7-40 and Ouverture and BV 7-40 are connected via masterlink:
BV 7-40: V.OPT = 2
Ouverture: A.OPT = 0
Good luck!
Regards
Räuber
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 8:39 AM
Thanks for that, does it all need re-optioning if I add a tv?
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 2 2012 9:48 AM
No, if you add a Beovision via masterlink in another room, this BV has to be set to V.OPT = 6.
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 10:31 AM
If this is already set to option 6 after adding the new master will I need to re-option it? Thanks for the help
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 2 2012 11:16 AM
Nick:
No.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Sep 2 2012 11:33 AM
Raeuber:
Sorry - not quite correct. If your BV is the main TV, the videomaster, set V.OPT to "2", no matter in which room it is installed. V.OPT 6 is a slave mode for link TVs.
Assuming you have a BV7-40 MKII, which Pentas do you have - MK III? Did you set the mode switch to video?
Are the Pentas registered in the BV7 Speaker menu? Do you use fully wired Powerlink cables? As far as I remember, BL Penta need these PL cables.
Stefan
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 11:38 AM
Hi, i had a bv7-32 mk1 before and i wired it back the same now i have bv7-40 my penta's are mk2's, the penta's are set in the speaker menu and 7-4 is selected as the centre.
Hope this helps
Cheers Nick
stefan
Posts 2,920
stefan replied on Sun, Sep 2 2012 11:55 AM
So your Pentas have no Powerlink. Do you use Speakerlink or Line in?
Are the mode switches set correctly?
If I remember correctly the Pentas sould turn automatically after a certain time when signal disappeared.
Stefan
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 12:36 PM
Yeah they have power link, I will have to take a look later I need my pin code off the dealer on Monday
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 2 2012 2:43 PM
stefan:
Raeuber:
Stefan
Sorry, Steffan, a little bit misunderstanding. Of course:
- BV in mainroom (videomaster): V.OPT = 2
- BV in linkroom: V.OPT = 6
/Räuber
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 6:35 PM
I have definitely put the bv7 into option 2 and it won't turn the speakers on when watching dtv but they come on with the cd fine! I have connected my sky box with a hdmi to the dvi socket and a scart is plugged in for I assume the audio is this where I am going wrong?
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 2 2012 6:53 PM
But I assume your speakers will turn on if you press SPEAKER = 2 or 3 while watching TV!?
Take a look in the MENU: There you can define the speakers to turn on in audio and video mode. Set for video mode SPEAKER = 3. Then your two speakers and the center speaker of BV 7 will turn on when you press TV/DTV from standby.
/Räuber
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 8:54 PM
it works, when i press speaker 3, where can i find the menu to turn the speakers on?  Cheers Nick
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 2 2012 9:57 PM
I can only describe it with my german BV 7-40 3D as follows:
Press MENU (twice) on Beo4
OPTIONEN
TON
GRUNDEINSTELLUNGEN
LS FOR VIDEO (set to 3)
Nick
Nottingham
Posts 785
Nick replied on Sun, Sep 2 2012 10:04 PM
Raeuber:
OPTIONEN
TON
GRUNDEINSTELLUNGEN
Thank you, so much i managed to work it out in the english menu from what you have putBig Smile  Thank you for sticking with it
Page 1 of 1 (16 items) | RSS
