elephant:I have been away for several days and nights during which this thread seems to have doubled in size ! So just a little experiment I conducted this afternoon, before I saw all these posts, was 1. Using the X app (in beta mode) 2. Nothing started 3. Select the BLC NL/ML 4. Select from its device menu MUSIC 5 This started playing from the Essence in the other room my last Essence Deezer playlist item (ColdPlay ... how apt) but NOT to the Essence's speakers 6. My ML destinations activated and playing to their speakers (as MUSIC is defined on that side of the BLC as Net.Music (and as my MacMini was not beolink/beoport active) with the source being the BLC and ColdPlay being the music 7. The setup unfortunately activated ALL my NL: BV8 and BS4 8. I deactivated the BV8 (red dot standby button) 9. I left the BeoSound 4 playing until A. The ColdPlay playlist came to an end and everything went quiet BeoNut since '75
Tried as you suggested. I selected the ML/NL that is attached to the BV7 in the X app. I went to music and tried to select a song from the DLNA server. I receive the error message "could not insert into playqueue". I then tried radio instead. Same issue, but a different error message: "action not supported by the selected product".
To clarify - I am using the beta version that is public as stable in the IOS store. I am not part of the testlfight betas. Has this bug been fixed in the meantime?
No,it's still an issue.
steve1977:Tried as you suggested. I selected the ML/NL that is attached to the BV7 in the X app. I went to music and tried to select a song from the DLNA server. I receive the error message "could not insert into playqueue". I then tried radio instead. Same issue, but a different error message: "action not supported by the selected product". To clarify - I am using the beta version that is public as stable in the IOS store. I am not part of the testlfight betas. Has this bug been fixed in the meantime?
BeoNut since '75
Got it. So, it is confirmed that the testflight beta is not at the feature set of the beomusic app yet when it comes to ML/NL support. Let alone adding more functionality.
Fingers crossed that this is being worked on and fixed soon.
