Install twonky and you can play your musicfiles direct from your nas
You can simply copy your files to the BM drive.
Depending on the OS/version are you using on your computer there are different ways to do so - basicly you must map the BM drive/music to your computer.
Or you could point the BS5 to the DLNA server on the QNAP - assuming that there is one running there with access to the files.
That would be the easiest solution.
Is your BM5 hardwired to the network - I suppose, that the QNAP is.
File structure: Artist, Album, Track. Be sure that you have the coverpic as folder.jpg (500x500) the Album folder and/or embedded in the files.
Reripping would be a big job depending on the amount of the cd's.
koning:Install twonky and you can play your musicfiles direct from your nas
Millemissen:You can simply copy your files to the BM drive. Depending on the OS/version are you using on your computer there are different ways to do so - basicly you must map the BM drive/music to your computer.
Or you could point the BS5 to the DLNA server on the QNAP ...
