I also was curious about the Avant / BeoSystem4 / BeoVision11 / V1 & Deezer issue and wrote to BeoCare.
Their first answer was, that their technicians are aware of an issue which causes the BeoSystem4 service not to work when Deezer is selected directly as a source, and they are expecting an update of the Deezer app. Until the Deezer update will be available, I should select Deezer via WebMedia.
Then I wanted a confirmation, that there will be a Deezer update for the BeoSystem4. Their reply was not that promising: BeoCare confirmed that the issue was reported to Deezer, but that they are unable to say whether and in such case when it will be fixed.
I’ll keep my fingers crossed.
Best regards
Doc Leisure
PS: Link to the original post: http://archivedforum2.beoworld.org/forums/t/23122.aspx
Thanks for your help
I logged in to webmedia then tried the deezer app
I hadn't used Deezer o the Avant and i dont know why i waited so long. It sounds wayyy better than the A9
I saved it to one of the my buttons - lets see if that will work! lol
OK
So i saved it to one of my buttons and it doesn't launch directly in to Deezer, it launches in to the "WebMedia" and then you have to select it
The functionality of my buttons sometimes I dont get. When i first got the Avant i had:
> My button with the terrestrial aerial and when you selected the my button it would start up and change the channel to the correct channel
> My button with my Foxtel (IQ2) and when you selected the my button it would start up and change the channel to the correct channel
> As soon as i changed to the IQ3 this doesn't happen anymore, it just changes to the last channel i had on , so it doesn't change the channel
Does anyone else have this with their cable TV boxes?
