Does your deezer work
This post has 6 Replies | 0 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Thu, Mar 30 2017 6:03 AM
Lately each time I try and use deezer on my avant it never starts
I get the splash page and that's it
Is there any way to reset it ?
CB
> You are Here <
Posts 1,762
CB replied on Thu, Mar 30 2017 6:54 AM
I was listening to the radio this morning (started automatically by the alarm clock) on my BS35 (so NOT an AVANT TV).
Then, using the Android X app, I changed to a song on Deezer.
Works perfectly.
But then, I tried to go back to the same radio station, and the problems started...
No more sound, wathever I choose (other radios of Tunein or Deezer) or do (pause or deep pause), from the X app or the control panel.
The only way to be able to ear something was to unplug and completely restart the BS35.
Aussie Michael
Melbourne, AU
Posts 3,730
I was thinking when you just press the deezer input solely on your Avant?
Thanks CB Big Smile
DocLeisure
Posts 101
DocLeisure replied on Thu, Mar 30 2017 11:04 AM
I also was curious about the Avant / BeoSystem4 / BeoVision11 / V1 & Deezer issue and wrote to BeoCare.
Their first answer was, that their technicians are aware of an issue which causes the BeoSystem4 service not to work when Deezer is selected directly as a source, and they are expecting an update of the Deezer app. Until the Deezer update will be available, I should select Deezer via WebMedia.
Then I wanted a confirmation, that there will be a Deezer update for the BeoSystem4. Their reply was not that promising: BeoCare confirmed that the issue was reported to Deezer, but that they are unable to say whether and in such case when it will be fixed.
I’ll keep my fingers crossed.
Best regards
Doc Leisure
PS: Link to the original post: http://archivedforum2.beoworld.org/forums/t/23122.aspx
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks doc. I'll try by web media tomorrow. It's annoying. Lol.
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks for your help
I logged in to webmedia then tried the deezer app
I hadn't used Deezer o the Avant and i dont know why i waited so long.  It sounds wayyy better than the A9
I saved it to one of the my buttons - lets see if that will work! lol
Aussie Michael
Melbourne, AU
Posts 3,730
OK
So i saved it to one of my buttons and it doesn't launch directly in to Deezer, it launches in to the "WebMedia" and then you have to select it
The functionality of my buttons sometimes I dont get.  When i first got the Avant i had:
> My button with the terrestrial aerial and when you selected the my button it would start up and change the channel to the correct channel
> My button with my Foxtel (IQ2) and when you selected the my button it would start up and change the channel to the correct channel
> As soon as i changed to the IQ3 this doesn't happen anymore, it just changes to the last channel i had on  , so it doesn't change the channel
Does anyone else have this with their cable TV boxes?
Page 1 of 1 (7 items) | RSS
