Hi
I am now using Beolink2 app for iPhone and iPad, There is now a group for Scenes, Cameras, Shades etc.
On the Beolink Gateway I can choose a resource as shade. Does anyone know what criterie or what kind of products can be used as shades.
I have IHC from L&K (Schneider now) - I guess IHC is more or less Danish, but maybe others know. I have shades from Somfy, but controlled by the IHC.
Is the shade group only limited to a certain product or is this meant to be for all products.
Of course, it would be nice to groups my shades in Beolink2 right - today I have this as a scene
(yes, I have tried B&O Support - only answer is to talk to dealer)
BR Rudi
Eclipse 65V1-32Beosound M5Essence MK2BLI
For your information....
Next week there will be an update of the BLGW firmware to version 1.5.2 - this will ad the functionality, so you can add any resource to any bottom on the Beolink2 app
Hi, Can you share how you got the new SW, as my firmware are only version 1.5.1.1 (after I run the online update).
Any tricks you can share? Or a link to the firmware download, so I can upload it manually.
Regards Mille
I STILL cannot get the content to work for the BeoSound 5. Very upsetting.
You need to know the hidden secret of Bang & Olufsen. In nearly all new products, there is a funny function build in. ;-) to cheat everyone - try a power reset before update and you will see it is working. (bad software/hardware....) This is also valid to many other brands these days...
No. It still does not function. Yet another reason to lose faith in B&O's software teams.
I was able to get the update. I'm referring to the BeoSound 5 content not loading.
Hi, Do anybody know how to make IHC room Temperture control into MLGW and out on Link2?
Light and Shades works perfectly after the 1.5.2 update this week :-)
BR Mille
