Network Solution for Multiroom Setup
zerocool143
Posts 94
zerocool143 Posted: Thu, Apr 27 2017 11:51 AM
Could someone suggest me the best pratice network solution setup for B&O Multiroom.
I'm always facing problem during installation. Most of the time there is dropout even if I use there recommended router which is Linksys EA6900.
Hope someone could give suggestions.
Tassos
Athens
Posts 323
Tassos replied on Thu, Apr 27 2017 12:24 PM
The way I have done mine is:
ISP router switched to modem mode connected to a linksys wifi router. Each subnet is connected to one of the router's LAN port (imagine a tree style connection). Each product connected (using wired connections wherever possible) to the switch. It works like a charm.
Infrastructure is: 2x cat6 utp from each room to the server room. All appliances (modem, router, server, etc) are in the server room. Switches (subnets) are used to each room when needed (i.e. more than two network appliances present).
Millemissen
Flensborg, Denmark
Posts 14,680
Tough question to answer - without knowing your location, rooms, environment in general.
Is your home surrounded by several other wifi networks etc.......
How are the settings of the router........
Do you use wifi exclusively for the connections.......
Which kind of 'problems' do you have.....
Maybe this document can be of inspiration?
Maybe go straight to page 65.
http://beointegration.com/uploaded/EN-BeoLink-handbook-v1-7.pdf
Mr 10Percent
So West, Its Now East
Posts 591
Other than configuration settings - which I cant help you with....I have a ground floor WiFi Router, main B&O A/V/Web setup, Ditto 1st floor and office/bedrooms/NAS on the 2nd floor. All connected via LAN over Power converter. Each converter socket enables hard connection or wifi/wifi boost in its own right.
All works faultlessly
zerocool143
Posts 94
Basically, my setup for network is one main router plus one switch then accesspoints on each where it is needed.
Cat6 cables are the ones available in the villas we are installing B&O
And recommended brand of routers and accesspoints?Like Ruckus,Aruba,Ubiquiti,Cisco etc
Normally I use only Linksys EA6900 for main router
Then Gigabit swtich like Tplink or Dlink
then for accesspoints WAP300N
mjmedlo
Posts 922
mjmedlo replied on Mon, May 1 2017 6:37 PM
Try Pakedge routers and switches.
B&O recommend and support.
Kiran
UK
Posts 1,023
Kiran replied on Tue, May 2 2017 9:29 AM
I will use all Pakedge equipment 👍🏻
Router, Switches, Wireless controller and WAPs.
This will be installed in 3/4 months.
Regards
Kiran
Born in NL; I ride ML
Page 1 of 1 (7 items) | RSS
