BeoVision 11 network connection issue
JC
West Yorkshire
Posts 764
Silver Member
JC Posted: Fri, May 12 2017 1:20 PM
HI all.
    Bit of advice and knowledge needed.
       We have our BV11 connected to the router via LAN and a NL/ML converter also connected. Every time I try to access webmedia  or radio/cd via the converter there is no internet connection and I need to reboot the router.
        Is it a better solution to have the TV connected via wi-fi, I am surprised if so as thought hard wiring the tv to the router would be seamless>
Cheers
 Jonnie
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, May 12 2017 4:18 PM
JC:
HI all.
Cheers
Jonnie
When I had a NL/ML and a BV11, I connected them wired via a switch to an airport express. The express was configured to extend my router network over wire. Between the express and the router it was a wired connection using Powerline adaptors.
Worked really well.
Sweden, Skövde
Posts 59
Martin replied on Sat, May 13 2017 9:09 AM
You could try to use fixad IP instead of DHCP to see if you get a more solid connection. It is usually prefered when connection software for DHCP such as b&o' is bad.
Page 1 of 1 (3 items) | RSS
