HI all.
Bit of advice and knowledge needed.
We have our BV11 connected to the router via LAN and a NL/ML converter also connected. Every time I try to access webmedia or radio/cd via the converter there is no internet connection and I need to reboot the router.
Is it a better solution to have the TV connected via wi-fi, I am surprised if so as thought hard wiring the tv to the router would be seamless>
Cheers
Jonnie
JC:HI all. Bit of advice and knowledge needed. We have our BV11 connected to the router via LAN and a NL/ML converter also connected. Every time I try to access webmedia or radio/cd via the converter there is no internet connection and I need to reboot the router. Is it a better solution to have the TV connected via wi-fi, I am surprised if so as thought hard wiring the tv to the router would be seamless> Cheers Jonnie
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
You could try to use fixad IP instead of DHCP to see if you get a more solid connection. It is usually prefered when connection software for DHCP such as b&o' is bad.
