Beosound 2 connection problem
This post has 13 Replies | 4 Followers
skafouris80
Posts 4
skafouris80 Posted: Sun, May 14 2017 11:17 PM
Hi!
Just bought a new BeoSound 2. I set it up as discriped through tha bang and olufsen site, using IOS. Everything was working fine but after a a few minutes as I was streaming radio from my phone it stop playing and dissapeared from the network ( beosetup, beomusic or airplay could not find any device). The led light on the speaker remained solid white like normal, but did not response to anything. Eventually had to pull the plug and restart to get it running again.... Same thing happen another 3 times.... any suggestions or should I return it to the shop?
Thanks!
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 8:32 AM
Log into product setup and do the firmware update.
Regards
Kiran
Born in NL; I ride ML
Kiran
UK
Posts 1,023
Regards
Kiran
skafouris80
Posts 4
Already did the update on initial setup.  Now it says «up to date».
Tried to reset and re install the unit. So far no problem.  Hopefully it has been resolved.
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 11:34 AM
Yes my next option would be to do factory reset.
Should all be okay now...
Regards
Kiran
skafouris80
Posts 4
Unfortunatelly problem not solved... Any more ideas?
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 15 2017 8:13 PM
This is strange.
Did you do a factory reset earlier?
I use my BeoCone everyday for 2 hours in the morning since December.
Firmware has been updated twice so far.
I can only recommend to contact the dealer...
Regards
Kiran
skafouris80
Posts 4
Went back to the dealer today and got a replacement. They also found it very strange... said they would look into it, but claimed that it could be my network....
Newone... so far works perfect!
Kiran
UK
Posts 1,023
Kiran replied on Thu, May 18 2017 9:59 AM
Happy for you mate 👍🏻
The BeoCone packs a massive punch 👊🏻
And there's a lot more control on bass and sound (free standing, flat wall, corner) after the firmware updates 👍🏻👍🏻
Regards
Kiran
sfriis
Posts 1
sfriis replied on Tue, Nov 27 2018 8:20 AM
Hi I also have this problem with my beosound 2 and also with my beoplay A6 - music stops and then starts again (as if there is too little buffer). Sometimes the system just stops and it is impossible to start it again.
Very bad
I love the speakers when they work. unfortunately, I get errors 2-4 times a month.
I have state of the art WIFI (unify) with signal good enough for streaming TV (errors is NOT when I watch TV).
Eddie8
Posts 5
Eddie8 replied on Sun, Apr 12 2020 4:06 AM
I have the same issue. Over the last week or so I was getting a “there is a glitch” message when I used voice commands. Rebooting the speaker did not help, so yesterday I did a factory reset and am now getting the message that “your device isn't set up yet, to get started download the google home app.” I spoke with a B & O customer support person and he said  it’s a Google problem and they are working with Google on a fix. Of course, I have no way of knowing if this is true.
Jaffrey2230
Washington DC
Posts 520
It is true this is a Google problem. There are many threads (non B&O) about this. You can try to create a completely new Google Account and try that way. I have a BS1 with GVA but don’t use the GVA and of course it is working on my device (sadly a wasted feature for me) 🤷🏻‍♂️
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
tjn2000
Posts 6
tjn2000 replied on Sun, Apr 12 2020 3:37 PM
I have the exact same problem its so annoying that it's suddenly stopped working.  I'd be interested if you hear about a fix.
VeruMunster
Posts 1
Unfortunately exacty the same thing in South Africa:
Google Assistant says you have to setup, even though according to Google Home App, it is connected.
I am able to cast to it via Spotify, but is is very buffery!
Missing the ability to play radio via Tune-In. Very frustrating in these time of Lockdown.
Page 1 of 1 (14 items) | RSS
