Hi everyone, Help needed please. I moved my 7-40 mk6, made all the connections and turned the power on at the plug. Everything worked ok. Since then I find that the only way I can turn the set on, is to power off at the plug and then back on. If I don't do that the standby light goes out and nothing further happens. I have the TV tuner disabled as I am connected to a sky box. I cannot switch on the bluray player unless I first turn of at the plug. It is as if everything freezes up. Any thoughts or advice would be gratefully received. Thank you.
PIN code issue, perhaps?
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
