Beovision 7-40 Mk6
beotrap
Posts 5
beotrap Posted: Mon, May 15 2017 11:19 PM
Hi everyone, Help needed please. I moved my 7-40 mk6, made all the connections and turned the power on at the plug. Everything worked ok. Since then I find that the only way I can turn the set on, is to power off at the plug and then back on. If I don't do that the standby light goes out and nothing further happens. I have the TV tuner disabled as I am connected to a sky box. I cannot switch on the bluray player unless I first turn of at the plug. It is as if everything freezes up. Any thoughts or advice would be gratefully received. Thank you.
Hungedu
United States
Posts 165
Hungedu replied on Tue, May 16 2017 3:18 PM
PIN code issue, perhaps?
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Page 1 of 1 (2 items) | RSS
