Finally had a chance to really play in the new App, using DLNA (Twonky). The app was snappy and pretty smooth. I think with a robust DLNA search added, it could be what I think I've been looking for from B&O. I'm still hoping for a potential new music system (not the Moment, not Essence) with all these features, so I can have a dedicated unit rather than use my phone -- but I'm not holding my breath.
I'm using the 1.0 iPhone version that came out yesterday. Other than the strange playlist with radiostations in it, I really like it.
But. I've found that suddenly after removing and adding radio favorites, the app plays random favorites with random icons. Not the station you select.
I've reported it via feedback in the app.
/ mike
jimcaj:after removing and adding radio favorites, the app plays random favorites with random icons. Not the station you select.
Regarding TuneIn favorites: We are aware that there is a problem and are working on a fix. Since the product itself gets the favorite list from TuneIn they get out of sync. Two workarounds that might work:
Sorry for the trouble
Thomas, Bang & Olufsen
Hi
I updated the app last night. I would love the app to have the ability to remove or add a selected few song to or from the queue. Right now you either renove/add one at a time or the entire queue/album.
Thanks,
Peter the Biker:Another little bit of good news for me: BeoSound Essence 1st generation is supported. It is my "Lord of the Penguins".Peter the biker
BeoNut since '75
djfairley89:However, when I open the X app the volume in the zone where I'm sending the stream races to max and even when the volume is decreased it shoots back up until the x app is closed.
@djfairlay89: The volume problem should be fixed. Could you send us a feedback describing the issue your are experiencing
MrAndersen: @djfairlay89: The volume problem should be fixed. Could you send us a feedback describing the issue your are experiencing
I am experiencing some unexpected behaviour, however it is probably designed that way.
On iPhone, when the App is launched, that is, either I am using it, or it is in the background, then the volume buttons on the iPhone controls the sound of my selected B&O product.
This is all fine and well when I am using the App, but when the App is in the background, and I am for instance browsing Instagram, the App should keep it fingers of the response from the volume buttons. When I find a video I would like to see, and turn up the volume to see it on my phone, the volume of the A6 also shoots up. I need to kill the app, before I start watching videos on my phone to only have the phone respond to volume buttons.
This is how it should work.
1. X App is active = respond to volume buttons.
2. X App is in background = keep hands off volume buttons.
When I have changed the volume on the phone with the app closed, and then open the app, the app also adjust the iPhone volume level, this also should NOT be done, the first interaction with the volume wheel should do this.
I know that the Now Playing screen is a cool feature, but there is to much overtaking of the phone from the App.
/Jacob
@Weebyx: This is a balance act and we will probably adjust it down the road. When the lock screen control is activated then we have the media session and also the buttons. We could make a similar option for the hardware buttons as we have for the lock screen. When disabled we never hook up the buttons, that might work. When you start a video from the phone this should take over the media session and we should no longer listen to the hardware buttons. If this still turns up the volume on your product then it is a bug.
MrAndersen: @Weebyx: This is a balance act and we will probably adjust it down the road. When the lock screen control is activated then we have the media session and also the buttons. We could make a similar option for the hardware buttons as we have for the lock screen. When disabled we never hook up the buttons, that might work. When you start a video from the phone this should take over the media session and we should no longer listen to the hardware buttons. If this still turns up the volume on your product then it is a bug.
If the X App is launched but in background, and I use Instagram and control the volume, this also turns the volume of my A6 up/down. So I guess this is a bug ? Do you need some logs or anything from me ?
@Weebyx: Yes please create a feedback ticket and I will take it from there
MrAndersen:@Sandyb: We will let users chose what folder to start from. So now it starts from the root, that is why it shows the folders you list. In your case you can chose the music folder and you would get the artist, album etc. at the top level. We cannot do it automatically since this might be in a different language or you might have renamed the folders to something else. This is completely customizable
MrAndersen: @Weebyx: Yes please create a feedback ticket and I will take it from there
Done... I have tried to write a way to reproduce it also, the forst time the app launches, volume buttons works as they should, the second time the app is active from background, and the put to background again, the buttons still control the sound of the selected device.
I just gave the new app a try. I am quite impressed. Much better than I'd anticipated. Great step forward and will even be even more once the missing feature will be added.
I am using the latest IOS (not beta), but ML/NL seems not supported yet at all. Is this still in beta? Any thoughts on my question below?
steve1977:i have a question for those using the beta, which i read here already supports ml/nl: does the new app allow to play DLNA directly to the ML/nl?
i haven´t been able to add the converter to the beta-x-app.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
@djfairley89: We have had a few reports of battery use, but cannot reproduce it here. Does the app stand out in the battery use list? Does it happen often?
@Fansastic: I have made a ticket for the Mement and meta data and will take a look at it
The ML/NL converter will be out in beta soon. Please let me know if you want to join the beta/testflight to try it out
@Fansastic: Just tried to repro the Moment issue, works on my phone when I start Deezer on the Moment. How do you start the music on the Moment?
MrAndersen:The ML/NL converter will be out in beta soon. Please let me know if you want to join the beta/testflight to try it out
MrAndersen:@Fansastic: Just tried to repro the Moment issue, works on my phone when I start Deezer on the Moment. How do you start the music on the Moment?
Hi MrAndersen,
I've been testing DLNA for some time and the app crashes a lot... Already commented on the app... But the DLNA is a welcome addition, and the small gap between songs is already better than my BS5 Encore!
Now the request : Apple Announced yesterday that Apple Music API will be made available for the devs... So let's add this streaming service (and don't forget Qobuz)!
diisign.com
mbee:...Apple Announced yesterday that Apple Music API will be made available for the devs... So let's add this streaming service (and don't forget Qobuz)! diisign.com
@mbee: We have an update in review that should take care of the crashes. Sorry about that. Regarding Apple Music, then yes we will be looking into it.
jimcaj:Trouble with the new iOS release version 1.02 (june 7th) of the X app. Note: I did get new firmware 1.14.11334 for the M5 today also. Maybe it's the combination of the two, that caused the trouble below. I don't know. I just spent 1 hour getting Deezer to play full length songs again on my M5. What happened was. Suddenly songs played very short. When I checked in the program, it said I was logged in. Apparently I was not, as Deezer wouldn't play songs to their full length any longer. I logged out - logged in. No change in behaviour. Closed program, cleared playlist. Didn't help. I kept repeating that and eventually, I got an (correct) error message saying - You are not logged in. Then I strugled with the password pane. Copy-paste is broken. You cannot first copy-paste your email in, switch to a password-app, copy password, switch back to paste it in. If you do, your email you entered previously, will be blanked out. I had to cancel. Start password pane again. Manually enter the email and then paste the password in - without switching apps in between. Then it worked again.
hallo! great job! Is there a possibility to play Songs in a playlist in random-play?
I am having real issues with the latest release. Nearly every time I start the app after having been in the background, the volume button and the "..." button does not respond. I have to navigate to somewhere else in the app, and back to now playing, and it works again.
Anyone else has these issues ?
Weebyx:Anyone else has these issues ?
jimcaj: Weebyx: Anyone else has these issues ? Hi. I'm on iOS. No issues with responsiveness here. I use Radio and Deezer and Spotify. IOS or Android?
IOS or Android?
iOS iPhone 6... easy to reproduce for me, happens almost every time :(
