beosound 5
This post has 30 Replies | 2 Followers
petelab8000
Posts 14
petelab8000 Posted: Thu, May 18 2017 5:07 PM
Hi to you all , ok first post , I've just got a Beosound 5 all good apart from 2 things , the first one is my beo 4 will work but intermittently most of the time it's a no no . I have 2 beo4s ,one works the beocentre 2 which is all fine , and is with the  TV in the living room and is plugged into the bc 2 phono inputs and that works fine , but upstairs where the bs 5 is,Ive plugged the phono in the bs5 and select aux nothing is coming out , am I missing something here , I tried other things blue tooth also iPad but nothing , any help would be grateful it's a great system just has a few things to sort out thanks Peter
beojeff
USA
Posts 2,012
beojeff replied on Thu, May 18 2017 5:48 PM
The BeoSound 5 must be set to audio master in the settings in order to access the aux input of the BeoSound 5. You can only have one audio master in a master link system. Maybe you have both the BeoSound 5 and the BeoCenter 2 connected to the ML and have the BeoCenter 2 set as audio master instead of the BeoSound 5?
petelab8000
Posts 14
Many thanks thanks for the info , bs5 is set to audio master also both systems are stand alone not in a ml set up . Thank you .
petelab8000
Posts 14
Thanks for the info , bs5 is set to audio master also it's not in a ml set to bc2 regards Peter .
Millemissen
Flensborg, Denmark
Posts 14,680
Sorry what doyou mean by 'plugged the phono in the bs5'?
What have you plugged in and where???
petelab8000
Posts 14
Ok on the back of the back of the beomaster box is 3 phono sockets 1vidio & 2 audio , like bc2, so I've plugged into them then select aux . But nothing coming out , everything els is perfect , sorry not the video just audio .
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, May 19 2017 8:59 AM
The phono sockets on the back of the BeoMaster 5 are not audio inputs. You need to purchase an adaptor to use the USB input. You can purchase this device made by Behringer U-CONTROL UCA 222.
Regards
Opman
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 9:39 AM
This is what you need...
Works totally fine for me - A.AUX
Buy the 3.5mm to RCA from Steve @ Sounds Heavenly 👍🏻👍🏻
I have been trying to find mine but its somewhere lost in the house lol...
Regards
Kiran
Born in NL; I ride ML
Millemissen
Flensborg, Denmark
Posts 14,680
Installed one yesterday (along with a Playmaker).
That definitely works - and it is also the official recommendation from B&O.
Millemissen
Flensborg, Denmark
Posts 14,680
petelab8000:
Please note, that if you intend to connect the audio of a tv this way, you will probably run into sync problems due to rhe processing of the sound in the connection chain.
StUrrock
Posts 995
StUrrock replied on Fri, May 19 2017 11:42 AM
Millemissen:
Horrible sound quality Devil not B&O at all
petelab8000
Posts 14
Guys thank you so much , you know yr stuff , have ordered a Behringer uca222 it's coming Monday , just one more thing , if they work on my bc2 , what are they for on the beomaster 5 then ?? Thanks again for all yr help ..
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Millemissen:
petelab8000:
Hi MM,
Yes, you are quite correct, the Beomaster 5 processing causes a delay to sound that comes in through the USB input, which will cause lip-sync issues if you try to connect a non-B&O TV this way.
The only solution to this is to buy a Beolink Converter from Bang & Olufsen (type 1161166) and connect this to the Beomaster 5 with a Masterlink cable: http://soundsheavenly.com/48-masterlink-control-and-sync
You can  connect the headphone output of the TV into the B&O converter with this cable:-
http://soundsheavenly.com/bang-olufsen/67--trs-5pd-.html
You can then listen to the TV through the Beomaster 5 without an audio delay by pressing “TV” on your B&O remote control.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
petelab8000
Posts 14
Sorry forgot also my beo4 remote will not work it have tried both so know it's not them , any ideas . Thanks
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 2:23 PM
Steve at Sounds Heavenly:
Steve you have just solved my ultimate problem for non B&O TVs! Thank you!!!
But now that the 1161166 converter uses the Masterlink slot from the audio system, how can I incorporate this converter into a whole masterlink for that 1 specific non B&O TV? Can I just patch the 1161166 converter into the RJ45 Masterlink patch like below?
Regards
Kiran
Posts 2,165
Hi Kiran,
Glad to hear that is helpful! Cool
Yes, as long as there are no other B&O TVs on that network, you can simply patch the Converter into the ML distribution box and link the non-B&O TV to the Converter.  Any video button on your B&O remote will then trigger Converter to play sound from the non-B&O TV via ML.
If you have other B&O TVs on the same ML network, then some planning will be needed in terms of option settings, otherwise you could activate every TV each time you select a video source......
Steve.
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 2:39 PM
Thank you Steve! This really has helped me a lot.
In the main house, all upstairs bedrooms currently have B&O audio systems but Samsung TVs. I plan on replacing these really slowly but what you have confirmed will help so much with current full integration 👍🏻💯🔥
Especially with my bedroom setup... I really like my Samsung 60...
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Fri, May 19 2017 3:35 PM
Can someone please explain the difference between the UFO-202 and the UFO-222.
I have the UFO-202. But there is also a UFO-222 available with the same connections.
Both say ultra low latency...
Regards
Kiran
Millemissen
Flensborg, Denmark
Posts 14,680
The colour!
Posts 2,165
I prefer to use the Behringer UFO202, as this also has a switchable phono pre-amp fitted.
Steve.
Kiran
UK
Posts 1,023
Kiran replied on Sat, May 20 2017 9:52 AM
Millemissen:
The colour!
That red does look really nice 😂👍🏻
Regards
Kiran
petelab8000
Posts 14
To all the help you guys gave thanks so much . I still have a problem with my beo 4 , it will not work the bs5 ,oh it works some times but most of the time it's a no no , I've used a second beo 4 still no good any help again guys , thanks Peter
Kiran
UK
Posts 1,023
Kiran replied on Sun, May 21 2017 11:36 AM
I really don't understand what you mean by this...
Can you explain more...
Does the remote work fine with other products?...
Regards
Kiran
petelab8000
Posts 14
Yes Kiran , both work with my bc2 , my century and beomaster 7000, they just don't like the bs5 for some reason , they will turn it of some times or switch to cd but as quick as they work they stop , very puzzled indeed .
Kiran
UK
Posts 1,023
Kiran replied on Sun, May 21 2017 11:55 AM
There's something wrong with the BS5 then?... or the receiver?...
I can't think if anything else...
Regards
Kiran
petelab8000
Posts 14
Damm , OK Kiran it's not the end of the world , it's set up in the main bedroom so just have to control it from the head unit , the guy I got it from really looked arfter is as its mint even the bm5 not one mark on any of them both , thank though .
Kiran
UK
Posts 1,023
Kiran replied on Sun, May 21 2017 12:19 PM
Do you keep any other B&O product in your main bedroom?...
Regards
Kiran
petelab8000
Posts 14
No , just  bs5 .
Posts 2,165
Is there a plasma TV in the bedroom?  These can interfere with B&O remotes.
Steve.
petelab8000
Posts 14
No Sony oled   , also shut everything down even moved the bs5 still nothing , think I'll just have to use it from the head unit .
oh also been let down with the Behringer UCA 222 did someone say you sell them Steve ?
Posts 2,165
Thanks for this, the OLED TV won't be a problem.
Yes, I have the upgraded UFO202 version (the same as UCA222 but with a switchable phono pre-amp fitted) here:-
http://soundsheavenly.com/input/17--ufo202-.html?search_query=usb&results=2
Steve.
Page 1 of 1 (31 items) | RSS
