Few beomaster queries
This post has 8 Replies | 0 Followers
Struer
London
Posts 106
Struer Posted: Sat, May 27 2017 8:51 AM
Dear Beoworld,
my Beomaster 1900 is stuck in stby no functions
my beomnaster 3000 does not respond to remote control
Beomaster 3400 heats up at the middle rear heat sink. The large tuning wheel cord has
also unraveled too, due to the broken rail guide.
any advise appreciated
kimd regards
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 27 2017 10:11 AM
Beomaster 1900
Was it put together correctly? If not, the sensorpads won't work.
Beomaster 3000
Which remote control are you using?
Beomaster 3400
Repair amplifiers. Replace idle current trimmers and readjust per the servicemanual.
Don't use it until repaired or you will risk more serious damage.
Struer
London
Posts 106
Beomaster 1900
I'll double check contacts are engaging properly... but I bought this from an enthusiast and he told me it was stuck on standby. I haven't been inside yet...
Beomaster 3000
I have used a BEO4 to control a beomaster 3300, so deduced the same remote might control the Beomaster 3000. Maybe this is not the case and the Beomaster 3000 can only be remotely controlled by the B and O terminal 3000?...
Beomaster 3400
I'm confident I can re align the pulley system, but the intermittent heat build up is a problem. Would that be some sort of capacitor needing replaced?
Saint Beogrowler
Saint Paul
Posts 780
Struer:
Beomaster 3000
Correct, the beo 4 does not work with the BM3000 and only the 3000 terminal will work.
Struer
London
Posts 106
Thanks for that, saint beogrowler
Saint Beogrowler
Saint Paul
Posts 780
For the 1900 you should be able to just remove the bottom plate and be able to look down between the PCB and the touch panel to see if the copper colored sensitouch contacts coming off the PCB (they are flat with a bifurcated fork end) are making contact with the silver colored pin coming down from the touch panel buttons. I thought I had a few pictures but I don't.
Dillen
Posts 13,191
Dillen replied on Sun, May 28 2017 7:59 PM
Struer:
Beomaster 1900
Beomaster 3400
No.
As mentioned earlier, replace idle current trimmers and readjust per the servicemanual.
Struer
London
Posts 106
Hi Peter, I've removed the Perspex
Button plate and have made direct contact with the silver prongs on the board with a small screwdriver No change from standby mode.
Kind regards
Kieron
Dillen
Posts 13,191
Dillen replied on Mon, May 29 2017 10:49 PM
Check if the oscillator for the sensorpad circuits is running.
Check the amount of ripple on the 15V rail.
Page 1 of 1 (9 items) | RSS
