Hello all,
When I want to use Beosound essence as master, the sound is too louder in the speaker and disconnected them.
What can I change ?
If you have access to a iPad and download the BeoSetup App (soon to be discontinued), you gan setup the Essence to a) give maximum volume (0-90) and b) show default start-up volume.
I assume the Android app does the same.
Mr 10Percent: ... BeoSetup App (soon to be discontinued)...
Sorry to hijack the thread, but will the BeoSetup App be replaced with the "X" app, or has B&O decided we don't need to configure it anymore?
Thanks,
Stan
In the X App, Settings >> My Product >> Select Product >> Configuration >> Sound
In the BeoSetup App (still available), select product and go to Sound
