Need Remote for Beovision 4-65 MM3 65"
This post has 1 Reply | 2 Followers
amare
Posts 6
amare Posted: Sat, Jun 17 2017 11:20 PM
A friend got a used Beovision 4-65 MMIII 65" wall mounted TV. It came without a remote. We tried to use remotes for Beovision 7-40 tv, but it doesn't turn on. Either the remote is not compatible or the sensor on the TV is blocked or something is wrong.
- Can anyone suggest how I can get/order the original or compatible remote for Beovision 4-65 TV?
- or suggest an idea how to make it work with the Beovision 7-40 remote?
- or any useful suggestion are most welcome
Sincerely
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jun 18 2017 11:21 AM
It may be that your friend's TV is set to Video Option '0', which means that it will not respond to IR commands from the remote.
Try this:
- Press the power (red dot) and LIST buttons at the same time, whereupon ADD will appear on the Beo4 display.
- Press LIST until OPTION appears on the display.
- Press GO (centre button), whereupon V.OPT should show on the display.
- Point remote at TV and press '1'.  The red power light on the TV should flash.
Now try the remote again.  Hopefully it will now work!
Page 1 of 1 (2 items) | RSS
