A friend got a used Beovision 4-65 MMIII 65" wall mounted TV. It came without a remote. We tried to use remotes for Beovision 7-40 tv, but it doesn't turn on. Either the remote is not compatible or the sensor on the TV is blocked or something is wrong.
- Can anyone suggest how I can get/order the original or compatible remote for Beovision 4-65 TV?
- or suggest an idea how to make it work with the Beovision 7-40 remote?
- or any useful suggestion are most welcome
Sincerely
It may be that your friend's TV is set to Video Option '0', which means that it will not respond to IR commands from the remote.
Try this:
- Press the power (red dot) and LIST buttons at the same time, whereupon ADD will appear on the Beo4 display.
- Press LIST until OPTION appears on the display.
- Press GO (centre button), whereupon V.OPT should show on the display.
- Point remote at TV and press '1'. The red power light on the TV should flash.
Now try the remote again. Hopefully it will now work!
