Beocenter 2 repairs
lausvi
Helsinki - Finland
Posts 689
lausvi Posted: Sun, Jun 18 2017 6:41 PM
Hi!
I have just bought a second-hand Beocenter 2 that was advertised as "spares or repair" having the following faults:
- After pressing LOAD the wings would open but the disc loader cover did not. After pressing LOAD the second time the disc loader opened and closed immeditately. I was able to fix this by following the suggestion in this old thread: took out and cleaned the drive belt with rubber restoring solution and now it works. Gotta love the wings opening and the cd tray illumination :)
- struggled to accept DVDs. Cleaned the lens with a cotton swab and IPA - was happily surprised to see the titles of my X-Files DVD showing up! Since that it has read all discs without any issues.
- DAB tuner not finding any channels. Not interested as we don't have DAB broadcasts in Finland :) Perhaps I should remove the module?
Now that most of seems to be working, I still have the following issues:
- The volume up/down ring struggles to work; it has one or two spots where it most likely responds but mainly I can keep rolling my finger around the ring with no response. The surface looks pretty much clean, but I will try cleaning it better. All other buttons work, but I feel like I need a bit more push than simple touch to work the keyboard, I can't say if it's normal as I have never used another BC2.
- The surface of the socket unit has a sort a soft-touch rubber finishing. In my unit something has happened to the surface coating and it has turned sticky. Apparently I am not the only one having similar issues. Any ideas on how could I clean it? I am not concerned if it won't look good, but I would like to get rid of the stickyness as it really collects all dust and even sticks to the floor!
- I am looking for the original table feet; posted a wanted thread here.
Thanks for ideas.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 9 2018 9:43 AM
lausvi:
Hi Lausvi,
did you ever find a solution for this?
I put DCfix in matte black on the surface as a workaround.
But still want to know how to remove (not cover) the stickiness.
Ralf
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Fri, Feb 9 2018 3:39 PM
Hi Ralf.
No, the BC2 has been sitting on the self looking pretty for quite some time now... Haven't have time to work on it.
On a related note; I don't recommend wrapping the socket unit in bubble wrap for storage... (it really sticks well!)
marexy
Posts 710
marexy replied on Fri, Feb 9 2018 4:44 PM
hi
i did one of my BC2 socket unit ...so
clean all sticky surface with paint remuver and then just spary it with plastidip mat black :)
looks like original :)
Page 1 of 1 (4 items) | RSS
