Hello BeoWorld
Greetings'
Quick, but not possitive.
As far as I know the BL5 is the only BL, that does not work with the (WiSa) Wireless transmitter/receiver combo.
Any other third party Product can we use ? or can we use one receiver of each BeoLab 5 speaker?
I would strongly advise against trying to make Beolab 5 wireless. They are not designed for this and (despite testing many wireless products from different companies) there are none that I could recommend in this case. As MM has mentioned, Beolab Transmitter 1/Receiver 1 do not work with Beolab 5.
The best, simplest and cheapest option is always a direct cable to the speakers, even if you need to arrange some minor re-decoration to ensure that the cables are completely hidden.
Beolab 5 is one of the best loudspeakers in the World and you can easily ruin their superb sound with a poorly chosen wireless connection. If you need any help getting the best sound from these speakers via cables, please feel free to ask.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
I'd say so too.
And I was wondering how he was going to use it with the BL5's when connected to the BSys3?
I am new with Beo Family i don't no why anyone sale BeoLAb 2 small sub woofer .when Beolab 5 already have. it will disturbed low frequency of BL5 too.
Thanks all for your suggestion.
