hotel beo 4
This post has 15 Replies | 3 Followers
JONNIE
Posts 52
JONNIE Posted: Fri, Sep 7 2012 11:00 PM
Hi I have just acquired a hotel beo4 which only has tv/text/menu listed on top 3 buttons,also it has mute instead of list does anyone know how to add dvd/sat buttons etc to this at present it is only good for volume and on and off please help !!
MartinW
Posts 389
MartinW replied on Fri, Sep 7 2012 11:03 PM
Its a completely custom Beo4, the only way to get the extra features would be to buy a normal beo4 chassis and a normal beo4 keypad, take the unit apart and replace the old chassis and keypad. Cost around £100.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Sep 8 2012 7:34 AM
I suggest you sell it and buy a full-blown Beo4 instead.
The hotel version may be of interest to a collector and it would be a shame to alter it.
With a little luck, it might even bring more than a good working "normal" Beo4 costs on Ebay.
Nick
Nottingham
Posts 785
Nick replied on Sat, Sep 8 2012 7:44 AM
Hi, you need to get a set of buttons and pcb for a beo 4 and swap them over, cheers Nick
kokomo
Spain
Posts 206
kokomo replied on Sat, Sep 8 2012 8:33 AM
Is "acquired" a euphemism?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
kokomo:
LOL -  I would have "acquired" the Beovision Devil
JONNIE
Posts 52
JONNIE replied on Mon, Sep 10 2012 8:46 PM
Cheers guys thanks for info and sorry to say it was included in a purchase with a mx4200 however these were from a 5 star hotel chain which was updating to lcds!
Thanks again !
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Tue, Sep 11 2012 11:28 AM
JONNIE:
Thanks again !
In which case the MX4200's "may" have the B2B module fiited. This allows the sets to work with the hotels system. You may need to disable the B2B module for the set to work once you have sourced a standard Beo4.
Opman
JONNIE
Posts 52
JONNIE replied on Fri, Sep 14 2012 12:31 AM
 great did that and I can now operate with standard beo4,however I have managed to add a aux to hotel beo4 using standby/list(mute) button and can use it with my aux connection with my beosystem hifi,however I wish there was a way to turn on my mx4200 with hotel remote it turns it on to tv, which is just a fuzzy picture as going via sat box ,however the hotel remote does not have vtape option when searching through add etc ! I want to turn it on with vtape mode as I have a sat box connected,the standard beo4 does it fine and get satellite picture straight away  but I really want to get hotel beo4 to do more I am sure it can as has config,add,option etc but I just dont know how !
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Sep 15 2012 12:17 PM
Set up the first TV channel as if it has a Decoder attached to the SCART - the tuning menu should allow you to do this.  Then this SCART input will be selected when you switch the TV on using the hotel remote.  I do this with one of my Beovisions.
JONNIE
Posts 52
JONNIE replied on Mon, Sep 17 2012 8:09 AM
hI can you explain in detail how to do this I am unsure !
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Sep 17 2012 8:34 AM
I don't have an MX4200 but have worked the following out from the manual, available on site if you upgrade your membership!
In the CONNECTIONS menu, select DECODER for the scart socket that your Sat Box is connected to.  Don't forget to press GO to store.
Then you need to go to the tuning menu, via TV SETUP then TUNING.  I think you need to go to the EXTRA menu and then simply select DECODER for the station being tuned.  Agaiun, don't forget to store the setting.
This should then switch to the 'decoder' scart socket when you select this station via TV.
JONNIE
Posts 52
JONNIE replied on Mon, Sep 17 2012 3:09 PM
Fantastic did it !! Tv now turns on when press tv on beo 4!!Thanks so much !!and I will upgrade ....
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Sep 18 2012 7:46 AM
No problem ; glad that I could be of help and many thanks for letting us know that it worked!
JONNIE
Posts 52
JONNIE replied on Wed, Sep 26 2012 11:12 PM
hI i have a  b and o dvd1 connected to this as well as my sat box , do you know of anyway I can get dvd to work off remote also ? Its just that I need to keep getting my other beo4 when I want to watch dvd
AndySol
Posts 1
AndySol replied on Wed, Jan 16 2013 7:22 PM
Hey Guy
Thank you so much for posting that thread.
I am the culprit for selling all the Hotel B&O MX4200's all 700 so far and most of my buyers plugged in their item and it worked first time, but there were the occasional times when I lost a sale because I couldn't get it to store the SAT box, Freeview etc. One of my buyers found your thread after getting home and experienced this problem. He was such a nice guy (excuse the pun) and sent me your thread. I've now tried it myself and it works just fine, so much so I hope you don't mind but I now give all my new customers your link.
Many Thanks Again
Page 1 of 1 (16 items) | RSS
DigiCert Secured Site Seal
