Hi Fellow B&O users.
I have just got a pair of H9.
Super nice.
I have paired it with my telephone - no problem.Easy.
But now I want to pair it with my laptop.With bluetooth.The PC can see and pair the H9.
But the sond comes from the laptops internal speaker !
What to do ??
Hi and welcome,
I think we need to know which kind of PC/laptop, you have.
Having bluetooth support doesn't not mean that it will send sound/sound in a reasonable quality.
Thanks a lot
My PC is a Lenovo T550.
Hope this helps ?
It is relatively new - probably has BT4.0 support.
Does something like this help?
Hi MM.
Thanks for your answer.
I will try some of your solutions later to day or tomorrow.
And no I have not tried to unpair the phone first.
I will get back to you.
Thanks for your answer. Now I got around to test your suggestions. And it worked. I disconnected the phone, and then I could connect the headset to the PC through Bluetooth with superb sound.
Thanks.
Br.
TheDustyBoy.
